It is currently Mon Jul 21, 2025 10:29 am
 Post subject: Wiring / alternator
PostPosted: Sat Apr 02, 2011 4:38 pm
Hey just need to know where this wire starts in my loom. Finishing at my alternator it needs to be replaced yellow/brown wire.
Cheers guys.
PostPosted: Sat Apr 02, 2011 5:21 pm
Mods rock!
The Brown / Yellow wire run up to the Instrument Cluster on a Clubbie / Rover or Speedo on a roundie. It goes to the IND (red) warning lamp.
PostPosted: Sat Apr 02, 2011 5:29 pm
http://www.niksula.hut.fi/~mdobruck/siililand/mini/diy/6/images/miniwire.gif
 Post subject: .
PostPosted: Sat Apr 02, 2011 5:42 pm
Cheers GT. Want to keep the colour the same .
Supercheap??
If not I'll scab some from work on Monday but it won't be the same colour.
PostPosted: Sat Apr 02, 2011 5:47 pm
Mods rock!
DTrain, that's handy.
Fiji, try supacrap and all the other usual suspects, You should be able to get Brown OK, but Brown with a Yellow Trace might be a bit hard to come by.
You could also go down the wreakers with some side cutters, don't have to look for a Mini specifically, but just about any Ford, Holden or English Car will have a Brown / Yellow wire.
 Post subject: K
PostPosted: Sat Apr 02, 2011 6:17 pm
Dtrain that helpful for future ref. Thanks
Solid idea Gt I was hoping to go out to Lillee's joint tomor see what was going on I'll run through a few wreckers see what I can pick up.
Cheers lads.
PostPosted: Sun Apr 03, 2011 12:20 am
Yep I got two Looms from Pick & Payless + the Original and cleaned them up and took the Best from the lot. You shouldn't have to much trouble getting a Brown with Yellow trace there. I always looked for the pommy cars first (Range Rovers also) as they are easier to get the full length out of
 Post subject: Normal?
PostPosted: Sun Apr 03, 2011 4:41 pm
Is it common practice for those wires to be all soldered together. I'm think not. Y/Br (burnt) runs to my alternator, it's not ind though. Brown to my solenoid +. the two bottom ones look to run under the dash .. Ignition I think.
The wires soldered above are the green from my alternator to the yellow from my speedo.
[/img]
