It is currently Sun Aug 10, 2025 5:24 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 226, 227, 228, 229, 230, 231, 232 ... 568  Next
PostPosted: Sun Apr 03, 2011 8:06 pm
Adam, ill post some photos up in the members area now :D
PostPosted: Sun Apr 03, 2011 9:13 pm
No longer a Mod of Ausmini
Connected the Temp gauge and Tacho driver side of Marcia so I can see them infront of the steering Wheels
1. Put a TDC mark on Gafmo's van's harmonic balancer, and checked the timing... found it was `a bit' advanced, idling at 33°BTDC... :shock:
It's OK now. 8)
Adjusted and Adjusted n Adjusted the front end Toe in/Out its now 2mm Toe out Thats close enough for me until someone with lasers can do it rather than a tape measure. Will see how it handles tomorrow
PostPosted: Sun Apr 03, 2011 9:25 pm
:lol: Good one, April fools was a couple of days ago though... you're a bit late :)
Sick of playing kindergarden teacher? Fair enough..
PostPosted: Sun Apr 03, 2011 9:26 pm
Yep..I'm getting back to the way I was before
PostPosted: Mon Apr 04, 2011 9:50 am
Milatsmadmini
Engine and subframe finally put back in the moke, still have a page of things to do (check wanted for wiring assistance... :lol: ), but its getting there...
PostPosted: Mon Apr 04, 2011 12:34 pm
Give Ash some flowers Nick .
Looks good matt but it might overheat a bit :P
PostPosted: Mon Apr 04, 2011 4:41 pm
Sent all the brake lines to Aust Brake Sleeving in Queanbeyan to be redone. Ten lines of various lengths, with connectors, for under $150!!!
I am a happy camper!!! Just wish the shocks would turn up so I can continue with the rear end redo!!
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Mon Apr 04, 2011 8:24 pm
Enjoyed driving to and From work today as the the frontend geometry is a lot better . Just amazing the difference, the Tyres can actually do their job now 8)
PostPosted: Tue Apr 05, 2011 6:37 am
yesterday:new windscreen rubber,rear bumperettes,new front carpet,new wing mirrors
PostPosted: Tue Apr 05, 2011 4:53 pm
Ordered 5/8in rear brake cyulinders and upper front bump stops. Still no shocks!! Trying to figure out which way the KAD shifter goes back into the rod change remote(and the bottom plate!!!)
See what happens when you pull something apart 3 years ago and try to remember where everything goes...grrrrrrrr.
Rob Forsyth
Miniot!!
PostPosted: Tue Apr 05, 2011 7:42 pm
Struggled some more trying to set the static timing, Turns out a mini engine turn clockwise eh?
PostPosted: Tue Apr 05, 2011 7:47 pm
Yeah the engine does, but the dizzy turns anti-clockwise. Just to confuse ya... :P
PostPosted: Tue Apr 05, 2011 8:20 pm
Recieved my parcel of goodies to rebuild my steering rack today. Now to remove, dismantle, clean, assess and re assemble!
Why do we put ourselves thru this stuff? lol
Jack of all trades, master of none......
PostPosted: Tue Apr 05, 2011 10:26 pm
http://www.youtube.com/watch?v=hpp67aqwM2Y :wink:
