It is currently Mon Jul 21, 2025 12:14 pm
 Post subject: starter not engaging
PostPosted: Tue Apr 05, 2011 2:57 pm
hey ,
i have just had my starter out as i was painting my engine. (1275)
Put it back in last night and it started the engine fine.
Went to start it this morning, and heard a horrible grinding sound as it was trying to turn the engine over. After a couple more tries , nothing. Took it out and bench tested it - its dead.
Luckily i have another starter from a 998. Bench tested fine. I have tried putting it in twice, and all i get is this horrible grinding sound as it tries to turn the engine.
What am i doing wrong?? I tried to grease the end of the starter, but no love.
PostPosted: Tue Apr 05, 2011 3:06 pm
Did you check the flywheel ring-gear before you put the other starter in? Sounds like you have something getting jammed between the ring-gear and the bendix,
oh and grease on the end of the bendix is eeeeevil ;)
cheers,
Jacob
PostPosted: Tue Apr 05, 2011 3:36 pm
no i didnt. im afraid you might have to explain to me what the flywheel ring gear is, where i find it and how do i check it?
I'm new to all this! :P
PostPosted: Tue Apr 05, 2011 3:46 pm
oh wait its just the edge of the flywheel that the starter engages into right?
i'll have a look
PostPosted: Tue Apr 05, 2011 10:29 pm
Tomboss Breweros
Take out the starter, wash off any grease with CRC/RP7/WD40, then dry it off by rinsing with petrol/brake clean/startyabarstard, then lube it with powdered graphite. Then the starter bendix will work as well as it can :wink:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Wed Apr 06, 2011 6:01 am
Mods rock!
Make sure that it feely slides (there is a bit small spring pressure) after doing this ^ otherwise you might need a new bendix.
 Post subject: Starter was Ok before.
PostPosted: Wed Apr 06, 2011 7:05 am
Is the car out of gear ? Secondly... You might have tightened the Terminal bolt a bit to much and spun the field coil link that is soldered to the inside of that bolt. This causes the link to separate from the terminal Stud making the starter "Open Circuit" Just my 2c worth.
"Let us remove your "SHORTS"
Users browsing this forum: Bing [Bot] and 88 guests
