It is currently Mon Jul 21, 2025 7:14 pm
PostPosted: Sun Apr 10, 2005 12:43 pm
gday
putting back my hinges today, something just wasnt right, would normal washers do?, i noticed that the bolt was angled a bit, normal ?
then came across this
http://www.freewebs.com/seefuh/weird%20washer.JPG
this could be the answer, but i only have two. anyone know where i could get them ?
thanks
Chris
PostPosted: Sun Apr 10, 2005 12:54 pm
Hmm yep.
Its where the door skin/A panel is curved.
If a normal washer is put in, it can bend the panel and make it obvious that theres a wrong washer in there.
Dunno if thats any help to you.
PostPosted: Tue Apr 12, 2005 5:43 am
Bump
Still looking for this washer :(
PostPosted: Tue Apr 12, 2005 7:01 am
Try Padstow Pirates, or Mini Suzuki Spares at 7 Hills.
Only the top hinge needs them, and really only on the tail end inside the door.. if you get desperate.
If you don't put one there you will bend the door skin. :cry:
:?: Check inside the door- they fall in there and people leave them.. :wink:
