It is currently Mon Aug 04, 2025 8:48 am
PostPosted: Thu Apr 21, 2011 12:35 pm
Re the electric sensor that sits on the drivers side in a bolt through a banjo in the engine bay.
Is that sensor supposed to sit up proud or screw right down onto the top of the bolt?
Mine's seems to sit high with a space between the bottom of the sensor and the banjo bolt. Meaning that the thread must be tapered?
So:
1. It's supposed to screw down on top of the banjo bolt OR
2. It's supposed to sit up high.
Regards,
Mike
"He who dies with the most toys wins."
 Post subject: Brake lioght switch
PostPosted: Thu Apr 21, 2011 1:14 pm
The brake light switch... If Brake lights work and switch or it's fittings don't leak... DO NOT TOUCH IT.
"Let us remove your "SHORTS"
PostPosted: Thu Apr 21, 2011 1:15 pm
Sits high but there is a copper washer under the shoulder against the banjo
David L
PostPosted: Thu Apr 21, 2011 1:34 pm
Its 9 to 10 I'm talking about. Rest is ok.
Space is between 9 to 10. I note that there is no washer shown on the diagram.
Never mind DON'T TOUCH IT. I've rebuilt my whole brake system including making up all the hard lines.
It's just I thought that the sensor should sit down hard against the banjo but it doesn't want to. Either inside the bolt or the sensor thread must be tapered?
Regards,
Mike
PostPosted: Thu Apr 21, 2011 6:38 pm
Mods rock!
The original switch sits high, not sure about replacements / aftermarket ones though.
Users browsing this forum: 1071 S, Gambo and 97 guests
