It is currently Tue Jul 22, 2025 7:19 pm
 Post subject: removing my engine
PostPosted: Fri Apr 22, 2011 2:40 pm
I am going to try and remove my engine over the Easter weekend
I read the how to thread that doogie posted and he said to drain the oil from the car almost first. Thats fine. If i manage to get motor out or dont
How long can i leave it with no oil or should i refill it with some cheapo oil?
Can i drain the radiator and cooling sys or will it rust quickly?
I have taken the twins off and there are two holes near the manifold
Should I put something in the holes to stop any rusting or will it be ok?
I have also removed the rocker cover and its just sitting on the head, Is that ok?
Any advice appreciated
PostPosted: Fri Apr 22, 2011 5:09 pm
The most important details you left out are how is the car being stored (ie in a reasonably sealed garage or out in the open)? and how long do you intend to store it. I would think a few weeks or more should be fine if garaged, but if in the weather (or worse - under a tarp) surface rust could start sooner in my opinion.
PostPosted: Fri Apr 22, 2011 6:10 pm
car is being kept in a saeled garage
PostPosted: Fri Apr 22, 2011 6:11 pm
the restoration may take some years as i have no clue what im doing, just learning along the way
PostPosted: Fri Apr 22, 2011 6:31 pm
Tip: don't let the radiator dry out unless you won't use it for a long time. Did that when I replaced the water pump on my Lancer, and the bloody thing overheated on the freeway as all the dried gunk blocked the system up and boiled it dry!
Cooper S Mk2
Cooper S Mk1
PostPosted: Fri Apr 22, 2011 7:09 pm
thanks for the tip. I was thinking of replacing it with probably a 2 core rediator but some people on here say to reco the old one. Mine atm seems to have a lot of white powdery stuff near the cap and on top of the radiator, could it have been overheating; temp seemed ok when last driving got a bit hot on hot days or in traffic but other than that was ok
PostPosted: Sat Apr 23, 2011 9:50 am
Most people store engines and engine parts in garages for years without issues. Yes I would seal all the obvious openings with cloth or race tape from what you now say. The rocker cover should be OK just lightly tightened back up. I wouldn't re-fill it with oil.
Are you not looking at rebuilding the engine anyhow?
for long term storage of individual engine items, most people spray them with WD40 or similar; or smear them with engine assembly lube or similar and wrap them in old cloth (not plastic as it doesn't allow the moisture out).
Hope that helps.
KB
PostPosted: Sat Apr 23, 2011 11:56 am
i am planning a rebuild im just not sure how surface rust might affect any components in any way for the rebuild. Just trying to be cautious
Users browsing this forum: Bing [Bot] and 75 guests
