Im nearly done with the restoration of the Steering Wheel Cowl. I've just done my first base coat in Satin Black (as suggested above).
Photo below: Cowl 1 just sanded
The following photo is of cowl 1, after it had the plastic cement sanded back.
Photo below: Cowl 1 Rear Support Patch
I added a rear patch for added support. I ended up purchasing a Styrene strip from the local hobby shop and used the same plastic cement to fuse it in place.
Photo below: Cowl 1 with Putty applied and sanded back
I purchased some plastic putty (epoxy) from the hobby shop too. I applied it, let it harden and then sanded it back. It may not be perfect but it seemed to do the job.
Photo below: Plastic Primer applied to Cowl 1
You may notice that some primer is missing from the cowl. That's because I dropped it whilst I was painting it... duh! It actually cracked the plastic and I had to patch it and reapply some more primer. (lesson learnt). One good thing out of that was that the original break held up.. no stress cracks or anything.
Photo below: First base coat applied
This photo was taken of both of the cowls (side by side) after the first base coat of Satin Black base was applied. I am very happy with the results so far.
Next I will apply one more coat of Satin Black... then I will apply a clear gloss coat. Thoughts?
