It is currently Wed Jul 30, 2025 7:40 pm
 Post subject: Reskinning my door
PostPosted: Thu Apr 28, 2011 9:02 pm
Hi All,
I've finally started to splash a bit of paint about.
I'm in the middle of respraying the inside of my drivers door and the replacement skin I got after Christmas and was wondering if I should use some seam sealer when it goes back together or if I should give a good dose of fish oil or the like.
Ian
PostPosted: Thu Apr 28, 2011 9:49 pm
When I fitted my new door skin I ran a bead of seam sealer around the edge in the join between the door skin and the door frame
I hope this will seal the water out plus it will assist with bonding the skin to the door
But I will still be spraying a lot of waxoil in the bottom of all panels
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Fri Apr 29, 2011 10:37 am
Hi Micheal,
That's what I'm going to do, can't have too much rust proofing.
Ian
1961 Morris 850 (being restored)
1965 Austin 1800 (daily driver)
