It is currently Tue Jul 29, 2025 2:14 pm
 Post subject: Rear adjustable brackets
PostPosted: Mon May 02, 2011 4:14 pm
Anyone had experience with these? I have a order in just wanted to add these if they're any good. Price seems ok
http://www.minisport.com/mini-spare-par ... S0510.html
What has everyone else used ? do they sell them at the likes of karcraft etc? Minisport au has some for 125 + postage.
http://www.minisport.com.au/prod19.htm
PostPosted: Mon May 02, 2011 4:48 pm
yeah i have a similar set on my car but i have these
http://www.minispares.com/Product.aspx? ... 381&title=
the adjuster screw makes it heaps easyier to do ..
can be a little fiddly and some wheel alignment places dont know how to use them ...
Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Mon May 02, 2011 7:45 pm
Mods rock!
The ones I use are similar to those in Beanie's post ^. They only do Camber Adjustement and for the Toe Adjustment, I shim the bracket. I use these because the set up has a method of adjustment that cannot slip.
That style of bracket from Mini Sport (UK) does both adustments by the one means, so when you get say the toe right, you've then got to slacken it off again to get the camber, but opps, there goes the toe adjustment again! You'd get there, but damm fiddley.
And, all you need is a bit of a decent bump and the toe adjustement will be out again.
Oh, yeah, and the brackets I use are only about $36 pr....... and I think a buck or less for a shim......
 Post subject: .
PostPosted: Mon May 02, 2011 7:48 pm
Thanks GT that was what I was after.
Can u let me know where u got them from? I'm in need of a set pretty soon.
 Post subject: Re: .
PostPosted: Mon May 02, 2011 7:52 pm
Mods rock!
Your welcome :D
PM sent
PostPosted: Mon May 02, 2011 8:00 pm
I also have similar to Beanie on my Dry Suspention Van and I got mine from KC
PostPosted: Mon May 02, 2011 9:50 pm
The Minisport (UK) versions are OK. Bit fiddly but no real hassle - and once set they stay in adjustment.
Cheers, Ian
PostPosted: Mon May 02, 2011 10:30 pm
I have a set on my car that look like all of the above combined. Serrated edges so they bite in, but adjuster screws to make life easier.
:D
