It is currently Thu Aug 14, 2025 3:03 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 237, 238, 239, 240, 241, 242, 243 ... 568  Next
PostPosted: Sun May 01, 2011 10:02 pm
looked at it, thought **** you, and then looked at it again. Why do you run on still.
PostPosted: Sun May 01, 2011 10:44 pm
Fitted the remote gear change. One last bolt will need a bit of work.
Tightened up the engine mounts. Fit now and no elongating of holes was necessary.
Fitted passenger side universal but will have to take of drivers hub to fit that side.
Exhaust not coming up to the exhaust manifold. Will need to reposition middle mount ate rear.
Can now refit oil filter, generator, starter motor and distributor.
PostPosted: Mon May 02, 2011 8:24 pm
Broke down in her. She can stay out in the Cold all alone for that
PostPosted: Mon May 02, 2011 9:27 pm
Steering cowl restoration nearly done (for George when he gets home). Wheel bearing caps banged, shaped and painted (for Dot). I know that no-one will see them but I know what they looked like.
George is still at the upholsterers.
1966 Morris Mini Minor Saloon (Dot) - 1275 Auto - Mongrel
1968 Morris Mini Van (Ivan) - 998 Auto - Mongrel
1968 Morris Mini.Matic (George) - Original
1968 Morris Mini.Matic (Charlie) - Original
PostPosted: Mon May 02, 2011 10:13 pm
got my minitastic springs in the post. Fitted the rear ones and will fit the front's later in the week/weekend.
I came home and the package that they came in had been put under the door mat. Funny because the box was a bit large to be under a door mat!
PostPosted: Mon May 02, 2011 11:04 pm
Mucked around with the wiring and alarm system. A lot of work to go but thats the fun of a universal setup I guess.
Then I stared at my rust and mind powered it to disappear. It didn't.
So... I'm Seifer
PostPosted: Mon May 02, 2011 11:55 pm
Fitted starter motor, slave cylinder and bracket. Earth strap.
PostPosted: Tue May 03, 2011 12:21 am
Fell off the wagon and brought another mini after five years without one.
82 BJ42 just completed resto
64 850 Modified(about to start rebuild)
PostPosted: Tue May 03, 2011 7:33 am
Put on a new rear boot seal and adusted my handbrake. Both confidence boosters Maybe, just maybe I can put it all back together again....
PostPosted: Tue May 03, 2011 10:33 pm
Fitted clutch slave spring, oil filter and bypass pipe, new oil pressure switch and adaptor for oil line, generator and coil, distributor- just fits around oil line adaptor.
Took rear number plate flap off to weld bracket back on, will not try to straighten again while fitted to bootlid.
Working out fitting of oil line using existing grommet for tacho wiring- using a boot type grommet.
Will need to make new plate for gear change boot and old one cactus and a bit small. PO made a hash of cutting the hole.
PostPosted: Tue May 03, 2011 10:49 pm
Push started it up and down the servo.
Knew I should have just filled up with the car on, damn those warning signs.
You're so square
Baby I don't care
PostPosted: Wed May 04, 2011 7:42 am
waited for my parts.
- in vain
apparently tnt express came to my house and found nobody home!
despite the fact i was home all day and left the gate open :roll:
PostPosted: Wed May 04, 2011 7:53 am
Received my eBay purchase today - original mini jack. Sand blasted it back to bare metal ... nice. Painted some other bits. Dot is still on stands - maybe today I will put the rear wheels on.
PostPosted: Wed May 04, 2011 2:33 pm
- in vain
got them today, apparently TNT don't deliver when it's raining :roll:
PostPosted: Wed May 04, 2011 9:22 pm
Fitted the trigger wheel to the pulley and adjusted so I have minimal run out with the trigger sensor. Now I need to drill and tap a few more holes and locktite all together.
Engine status. :) :)
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
Users browsing this forum: crisonic and 170 guests
