It is currently Mon Aug 11, 2025 5:15 am
 Post subject: MK2 Seat belt clips
PostPosted: Thu May 05, 2011 6:25 pm
Hi all I'm new to the group,but not new to Minis have had 11 over 43 years.
I have been enjoying the discussions and great Mini knowledge for some time now.
Just one question on seat belt clips (retainers) did Mk2s have the plastic clip just behind the" B pillar" below the window, mine has the holes but they don't look like they have ever had screws in them.
Thanks for the wealth of Knowledge.
1970 Mk 2 Cooper S
PostPosted: Thu May 05, 2011 6:36 pm
Yes they did have them fitted. Someone reproduced some a while ago, not sure if there are any still to be had. Took me 2 years to find 2 originals :shock:
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Thu May 05, 2011 7:12 pm
Mods rock!
John at Mini King had them made and still has quite a few.
PostPosted: Thu May 05, 2011 7:39 pm
Thanks for the info guys I thought so but couldn't remember nor could the better half. I have already purchased new ones but didn't want to fit them until I was sure, they must of been held on with very small self tappers does anyone know if they were phillips head or not
1970 Mk 2 Cooper S
PostPosted: Fri May 06, 2011 4:03 pm
Here is a link with a pic of one on a MK2 S. It was my first ever post!
http://www.ausmini.com/forums/viewtopic ... highlight=
here is another pic of one in a MK2 S.
The repro ones I saw were much greyer but the old ones I have seen are very brittle and snap in half easily. I got a set of originals a few years ago but wouldn't clip the belts on in case they break. I believe they were alaso fitted in morris 1100's so look there as well if you want originals.
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Fri May 06, 2011 4:25 pm
Flute wrote:
I learnt something a few months ago - is that screw a phillips, or is it the other type that looks the same but isn't?
PostPosted: Fri May 06, 2011 4:35 pm
I have Mini King repro clips in my 'S' and theyr'e very good. A lot stronger than OE. Certainly not afraid to put belts in. I try to remember to be gentle when removing just in case.
" I'll show you mine if you show me your's"
PostPosted: Fri May 06, 2011 5:52 pm
Pozi-Drive?
;-) Pete...
____________________
1968 Deluxe 1275
1969 Deluxe 'Scruby' 998 Looking for a roof skin...
 Post subject: Seat belt thingies
PostPosted: Fri May 06, 2011 5:57 pm
Hmm...
Might have to have a look to see if I've got any of those Cooper seat belt clips in my Landcrab parts collection. :lol:
Ian
1961 Morris 850 (being restored)
1965 Austin 1800 (daily driver)
PostPosted: Fri May 06, 2011 6:41 pm
Givers me the shivers just looking at that buckle hangfing up in the clip, even if you can get repros now.
Wasn't the stongest piece of BMC equipment ever designed..
PostPosted: Fri May 06, 2011 9:03 pm
Thanks for the info guys and thanks for the pic flute. I owned a 69 MK2 back then and yes it was Crystal White with blue trim I do hope you have my old car but I have no way of knowing. :twisted: Otherwise I would repo it. :D
1970 Mk 2 Cooper S
PostPosted: Sat May 07, 2011 4:33 pm
That pic is one of Keiths minis from Sydney which won the mini show down here the year before last. He sold it to someone else up there who "had to have it" and shortly after it ended up at the auctions asking $50K! Wish it was mine.
Member: VMCI #2474
PostPosted: Sat May 07, 2011 9:39 pm
MiniPete wrote:
Pozi-Drive?
pozidriv size 2 fits most auto makers screws. You can tell the difference between positive dirve fastener and a phillips head screw by the four additional cross 'grips' to a pozi and that the drivers have square angle to the head rather than a more pointed head of a standard phillips head. *2 cents*.
PostPosted: Mon May 23, 2011 10:42 am
The Mini King
[quote
The repro ones I saw were much greyer but the old ones I have seen are very brittle and snap in half easily. I got a set of originals a few years ago but wouldn't clip the belts on in case they break. I believe they were alaso fitted in morris 1100's so look there as well if you want originals.[/quote]
The Ones I have made are the correct colour, There are other repros avail that are a different colour to the Ones we supply
