It is currently Thu Jul 17, 2025 10:01 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2, 3  Next
PostPosted: Tue Apr 12, 2005 3:58 pm
i have a dint im my clubbys passenger side bum which is making my boot leak. ehat would be the best way of removing it like what tools and also how does the fuel tank come out? there is a braket at the back of the fuel tank near the light is there any more ?
help
PostPosted: Tue Apr 12, 2005 4:15 pm
Bog.
you will never tap that out.
PostPosted: Tue Apr 12, 2005 4:41 pm
take fuel out of tank, take fuel hose off, undo the strap and pull tank out. IF it dosnt come out there maybe a tank bleed plug in the bottom going through the boot. You may have to get under the car and unscrew it. Then take the light out too.
Now take a hammer with a spade shaped head on it and tap away in side the boot, holding something solid on the outside of the car against the dent. Try to get it out as good as you can but dont hit it out to far. Then apply some bog.
1974 Moke - 998cc
PostPosted: Tue Apr 12, 2005 4:44 pm
according to the red mini folder,
under DIY body panel straightening,
pack the surrounding area with a great wad of asbestos
(pure form if you can get your hands on it)
and heat up the metal wacking it back in shape
Inconspicuously Conspicuous
PostPosted: Tue Apr 12, 2005 4:54 pm
i got no strap just a braket near the light thats all i can see
PostPosted: Tue Apr 12, 2005 5:07 pm
yeh ben its actually a strap that goes around the whole tank vertically
if thats just the section you can see (which does look like a bracket)
PostPosted: Tue Apr 12, 2005 5:10 pm
Don't forget to empty the tank and remove the battery eh! no silly mistakes with fuel tanks please! :shock:
PostPosted: Tue Apr 12, 2005 5:15 pm
just pull crap out until it comes....thats my approach...lol dunno if the mini runs anymore :oops:
I have a problem.. apparently
PostPosted: Tue Apr 12, 2005 5:28 pm
I dont think removing the dint will help... clubbies always leak :lol:
I am with 13secmini though. But use a hard rubber hammer one side and a rubber dolly the other if you can. Saves the paintwork.
PostPosted: Tue Apr 12, 2005 5:53 pm
the paint work is shocking anyway im going to respray it one day so im not worried abount the paint. so there is a stap that goes over and thats it? also how do i empty the tank? :? a silly question but im not sure
PostPosted: Tue Apr 12, 2005 6:02 pm
i tried to syphon mine, but i got petrol in my mouth, so instead i replaced the outliet pipe with a pipe i had laying around, real quick, spilled a little petrol.....but oh well.....better than tasting it , and just let it drain into a jerry can. thats how i did it. of course the boot was empty....
PostPosted: Tue Apr 12, 2005 7:41 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
you got a electric fuel pump or mechanical one ??
if electric remove the fuel pipe at the carby and insert into a jerry can and switch ignition on self drainer :D
makka
PostPosted: Tue Apr 12, 2005 7:43 pm
i got a mechanical cuase the electric died :(
PostPosted: Tue Apr 12, 2005 8:21 pm
from what i understand... your best bet would be a slide hammer.... drill a hole into the panel, in the centre of the dint, then you screw then end of the hammer in....
then, gently slide the hamer back and forth until the dint pops out... weld the hole over, bog it up and then respray
68matic: "i havent seen much head in my life "
PostPosted: Tue Apr 12, 2005 8:27 pm
My Mini clubman has the same problem. I have a dint in the same place. I just tapped it out with a panel beaters hammer and filled it with bog. No one will notice when it is painted. :D
