Wombat wrote:
Haynes would have said "remove adjuster"
The adjusters I just bought off GT say "Lever, saw,chisel or drill off the existing adjuster"
- Something tells me it's not going to be easy
Well,after you fix the grinder
, cut the tops off them, then drill them off. Fiddely, yes, but shouldn't be hard.
Angusdog wrote:
Every mini owner should have a
thermic lance in their toolkit.
I do actually have one of them. Great for piercing steel of any thickness, eg, I can put a hole through the head of rail track in less that 2 seconds. Will also cut concrete! The rods are a bit dear though.
Oh, and I wouldn't recommend it for safe cracking, what ever was inside wouldn't be much good after hitting the safe with it.
