It is currently Sat Jul 19, 2025 4:44 pm
 Post subject: Help on Belt Kit...
PostPosted: Thu May 26, 2011 10:15 pm
I have the Triger kit on the car and lined up the dots(RE13 GR cam - 106 deg LCA). I think I asked a looong time ago; however, will I be able to get away with this for the road use.
Not interested in blowing the doors off it, just a reliable daily for me...
Hooroo
PS - will be trying to get some of the locals from the ACT/surrounds to assist in my final assembly...standby for pipes(mainly engine bay and wiring stuff...). If you want to come from further afield, will feed you all and offer a bit of floor... :D
Rob Forsyth
Miniot!!
PostPosted: Fri May 27, 2011 9:42 pm
I put my RE282 in the first time by lining up the dots on the duplex chain gear and it made 127hp :lol:
Give Graham a call to confirm, but you should be OK with lining the dots up on the belt drive if you are not concerned with ultimate power.
michael
PostPosted: Sat May 28, 2011 7:15 am
Thanks Mick - I changed the belt for the sake it sat there for 3 years on the cogs. Managed to get a Gates one from a supplier here - good for another 3 years of sitting on the garage floor!!
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Tue May 31, 2011 2:39 pm
I found you DO need an offset key with the early Triger belt drive kits.
I needed a 6° one in the RE282 cam (my 1360) and a 5° in the RE13 (wife's 1412 stroker).
Also it depends who is grinding the cams- I needed a 9° key with my Camtech VP3.
PostPosted: Wed Jun 01, 2011 9:11 pm
Thanks Kev - well I have another issue now as there is supposed to be a plate on the crank nose which keeps the belt from coming off. Some say that you use the oil slinger from a chain driven setup; however, I fitted the slnger and there is barely any keyway left to put the harmonic balancer on the end. Further, when I torque it up, it will cause the slinger to bend and flare as I screw the crank bolt in.
I need some learned advice from the forum as it is doing my head in...lol
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Wed Jun 01, 2011 9:12 pm
Do NOT use a normal slinger.
I have a rough sketch I did for a bloke in Perth, to machine one up-
and it fitted fine he says.
http://home.exetel.com.au/zoomini/zoomi ... flange.jpg
Last edited by drmini in aust on Wed Jun 01, 2011 10:15 pm, edited 2 times in total.
PostPosted: Wed Jun 01, 2011 9:16 pm
Thanks Doc - will pay hansomely for it!!
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Sun Jun 05, 2011 6:08 pm
Update on the belt drive. I have used the drawing from Kev to show Terry at QIM in Queanbeyan and will have it done in a week or so(he has to replace the workshop compressor as it went boom...)
It will be 2mm aluminium alloy cut from solid bar and machined to the specs. Should keep the bloody belt from coming off in the future. Pics to follow when I get it...
Thanks to the good Doctor - comes through yet again!!
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Sun Jun 05, 2011 6:40 pm
Rob, please use steel (1040 grade or better), not alloy. Otherwise, it will squash when you torque the crank pulley bolt up to 75 lb/ft...and the bolt will come loose. :shock:
PostPosted: Sun Jun 05, 2011 9:52 pm
Hmmmmm welll why did the maker of the Minispares belt kit say the bit was made of alloy bar in the kits they sell to the public...hopefully Terry hasn't made it yet...and if he has, well maybe lots of loctite :evil:
So called experts indeed :roll: . Will ring him in the morning then...
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Sun Jun 05, 2011 9:59 pm
Later kits were redesigned with a bigger seal diameter on the bottom pulley, for this same squashing reason. Apparently on race motors the bolt's clamp force was distorting the pulley where it contacts the crank.
As for Loctite, yeah use some 262 on the bolt instead of the lock tab- they squash these days too. Rubbish material...
PostPosted: Sun Jun 05, 2011 10:04 pm
Thanks Kev - well erry was trying to move the air compressor(was 8 feet high!!) so reckon he would have not started it as yet.
Loctite is anyones friend!!
Hooroo
Rob Forsyth
Miniot!!
