It is currently Wed Jul 23, 2025 1:40 am
 Post subject: Hydro pump gauges
PostPosted: Tue May 31, 2011 2:20 pm
rehab1964 wrote:
850man wrote:
Your machine retains its original Austaloy gauges but later machines had gauges made by Floyd instruments here in melb. I repaired a machine for Scott (Balistic) a few months ago and I contacted Floyd and they made me a new pressure gauge, and can supply the Vacume gauge too.
FLOYD INSTRUMENTS PTY LTD
24 TRADE PARK DRIVE, TULLAMARINE, VIC 3043
PHONE: (03) 9339 3400
FAX: (03) 9339 3411
I followed up on this lead in an attempt at securing some new gauges for my pump. I contacted Floyd and they have told me they can't do the original 50mm size, it will have to be 57mm. Also instead of the white dial/black numbers they can only do black dial/white numbers.
Can anyone tell me if the picture of the nice new gauges above is what was purchased from Floyd and if so why can't I get them :?:
Steve
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Tue May 31, 2011 2:48 pm
Mods rock!
My experience with Flyod is they don't usually like going direct but prefer that you go through one of their re-sellers. See if you can contact one of their bigger ones as they may have more leverage in getting what you are after.
I know Blackwoods are an agent for Floyds although I don't know how much business they do together.
PostPosted: Fri Jun 03, 2011 7:16 pm
The new gauge pictured in the photo above is what Floyd supplied. I did take the original 50mm gauge into them to have it reco'ed but they dont recondition gauges, they only supply new. Yes the new gauge is 57mm and the top cover required the hole to be enlarged. I delt with Folyd gauges directly, I just went to the factory and spoke to one of the managers. I had delt with them years ago so I had a good introduction.
If you want to keep the original gauges then I suggest you go and see Roger at Howard Instruments. He reconditions all sorts of old gauges and gets new gauge faces screen printed so I am sure he can help you with yours.
Have a Nice Day.
PostPosted: Fri Jun 03, 2011 9:52 pm
I sent my gauges to Floyd who reconditioned them. It took a while but they were fairly cheap and very good.
PostPosted: Fri Jun 03, 2011 9:54 pm
I sent my gauges to Floyd who reconditioned them. It took a while but it was cheap and good.
They've told me that they don't or can't recondition mine as well.
It seems that it may depend on who you talk to.
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Fri Jun 03, 2011 9:58 pm
I sent them to them with the idea that they could supply gauges the same size and scale.
The bloke out the back called me up and said he could fix them.
You need to talk to the bloke out the back.
PostPosted: Fri Jun 03, 2011 10:02 pm
Not sure how I will go calling up and asking for the bloke out the back :D
Sounds like it might be worth a try though.
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
Users browsing this forum: Bing [Bot] and 88 guests
