It is currently Sun Aug 03, 2025 5:17 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
PostPosted: Tue May 31, 2011 2:04 pm
Noticed last night after an oil change and degrease that there is a little hole (about the size of my little finger) in the seal at the front/gearbox side of the remote. I remember my Morris 1100 was forever in need of new 'sandwich plates', but just wondering if there's meant to be a hole or I need to replace the whole seal/rubber sandwich plate. If so, whats the proper name of this rubber bit so I can order one?
PostPosted: Tue May 31, 2011 2:11 pm
There is a "half moon" sort of shaped piece of rubber that goes in there. I don't know exactly what they call it but it shouldn't take much explaining to a supplier for them to know what you want.
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Tue May 31, 2011 2:12 pm
This is it http://www.minisport.com.au/prod1120.htm
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Tue May 31, 2011 2:17 pm
Bingo. I was looking at the same. Anyone know if its a sh@# job or it plonks straight in?
PostPosted: Tue May 31, 2011 2:22 pm
It goes in fairly easily.
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Tue May 31, 2011 2:23 pm
So does it just slip in or is it remote out?
Thanks!
Evan
PostPosted: Tue May 31, 2011 2:53 pm
If I remember correctly you should be able to sneak it in with just loosening the remote and dropping it down a little.
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Tue May 31, 2011 3:07 pm
Thanks Steve. I will order one.
PostPosted: Tue May 31, 2011 3:42 pm
A while ago I needed one and was unaware they were still available. So I used some Selleys Allclear instead... `if it's selleys it works". :lol:
PostPosted: Tue May 31, 2011 3:43 pm
Funny... I was thinking the same thing last night!
PostPosted: Tue May 31, 2011 3:54 pm
In 30 something years of playing with Minis and 1100s I have never ever had a seal in a remote.
And I have never ever has a problem caused by it! :lol: :lol: :lol:
PostPosted: Tue May 31, 2011 3:58 pm
It's more important to have that flat metal cover over the slots on top (above the bellcrank's cross pin). Not all remotes got this cover, those that don't have a magnetic attraction for nuts/bolts/washers/random bits that fall down the back. This can spoil your whole gearshifting experience... :lol:
PostPosted: Tue May 31, 2011 4:32 pm
I fill my hole up with silicone ;)
PostPosted: Tue May 31, 2011 4:34 pm
Mine just fills up with a mixture of dirt and oil.
PostPosted: Tue May 31, 2011 4:38 pm
ewww, silicone is much nicer
