It is currently Sun Aug 03, 2025 7:27 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Tue May 31, 2011 6:08 pm
simon k wrote:
Mine just fills up with a mixture of dirt and oil.
ewww, silicone is much nicer
Gorilla snot
David L
PostPosted: Wed Jun 01, 2011 6:51 am
Panthersteve wrote:
If I remember correctly you should be able to sneak it in with just loosening the remote and dropping it down a little.
Yep. That's how I did mine. Just loosen the bolts enough and it slips in.
Question... Why is that plug even there?
PostPosted: Wed Jun 01, 2011 7:11 am
I looked at that one day and wondered the same thing.
The machined crescent I believe is concentric with the bore down the center of the remote change unit. Could it have been a need to give the boring tools access into the housing at the factory?
PostPosted: Wed Jun 01, 2011 7:36 am
Yes thanks, that makes sense. (throws Mintie in Micks direction.) :D
PostPosted: Wed Jun 01, 2011 9:29 am
good answer!!
PostPosted: Wed Jun 01, 2011 12:18 pm
It's more important to have that flat metal cover over the slots on top (above the bellcrank's cross pin). Not all remotes got this cover, those that don't have a magnetic attraction for nuts/bolts/washers/random bits that fall down the back. This can spoil your whole gearshifting experience... :lol:
This cover seems to be an Aussie addition, UK sourced cars don't have it. Some NZ cars do but those that do may have had one fitted here.
Al
PostPosted: Wed Jun 01, 2011 12:35 pm
simon k wrote:
I fill my hole up with silicone ;)
Can't believe this was just left alone..... :roll:
PostPosted: Wed Jun 01, 2011 12:36 pm
Al
I think I have a service bulletin from when BMC Australia introduced that cover.
PostPosted: Wed Jun 01, 2011 12:42 pm
Al
yeah, I've seen it, it says "this is an awesomeness cover, Australian minis are awesome, so they need this cover"
PostPosted: Wed Jun 01, 2011 12:47 pm
With gravel roads here, ya just know a stone 'ill find it's way in there.
Al
PostPosted: Wed Jun 01, 2011 5:30 pm
Haha the thought did cross my mind to say something cheeky, but best not to upset the Mods ;-)
;-) Pete...
____________________
1968 Deluxe 1275
1969 Deluxe 'Scruby' 998 Looking for a roof skin...
PostPosted: Wed Jun 01, 2011 8:29 pm
I know!! I left it out there, but no bites... I guess my hard work atbringing you lot into line is paying off! :twisted:
PostPosted: Wed Jun 01, 2011 8:43 pm
The Mini King
Cooper_Matrikon wrote:
Noticed last night after an oil change and degrease that there is a little hole (about the size of my little finger) in the seal at the front/gearbox side of the remote. I remember my Morris 1100 was forever in need of new 'sandwich plates', but just wondering if there's meant to be a hole or I need to replace the whole seal/rubber sandwich plate. If so, whats the proper name of this rubber bit so I can order one?
The Part Number You need to order is 22A285
PostPosted: Wed Jun 01, 2011 9:05 pm
1 of mine has the Rubber.
The other has Silicon.
I don't like dirt in mine
Users browsing this forum: Bing [Bot] and 87 guests
