It is currently Sat Aug 02, 2025 12:59 pm
PostPosted: Tue May 31, 2011 9:58 pm
I am trying to find a replacement heater radiator that looks like this:
Does anyone know where I can get one like this? If at all.
1966 Morris Mini Minor Saloon (Dot) - 1275 Auto - Mongrel
1968 Morris Mini Van (Ivan) - 998 Auto - Mongrel
1968 Morris Mini.Matic (George) - Original
1968 Morris Mini.Matic (Charlie) - Original
PostPosted: Tue May 31, 2011 10:06 pm
Go to "Bundoora Radiators" There around in the next street to the old Northern Mini Parts (in Heidelberg) They did all our radiators & heater cores and would have what you need/or have a modern replacment.
http://www.bundooraradiators.com.au/
Have a Nice Day.
PostPosted: Tue May 31, 2011 10:26 pm
The local radiator place (D&D Radiator Service Centre) quoted $290 for a replacement core - they said they'd have to make it.
What are your thoughts on what I would possibly be looking at ($$)?
PostPosted: Wed Jun 01, 2011 4:25 pm
I would just look for another S/H MiniMatic heater, there are plenty around still. These were also a factory option on Mini Deluxe and K.
PostPosted: Wed Jun 01, 2011 5:44 pm
Mods rock!
Adrad do replacement cores and I doubt it would be $280, probably closer to $80.
PostPosted: Wed Jun 01, 2011 6:46 pm
I ended up going to Bundoora. Russell was good to talk to and estimates 200 smackaroos.
I figured that I would only need to do this once .... And I'm impatient.
I've just pulled the heater housing apart and am ready to sandblast it.
After that I will get a rust spot repaired before I paint it.
Then i get to put it all back together.
PostPosted: Wed Jun 01, 2011 9:37 pm
Came home tonight and sand blasted the heater surround.
Here is some rust that I found:
Does anyone know anyone in the West (near Deer Park) that can fix this rust for me?
PostPosted: Wed Jun 01, 2011 9:47 pm
Anyone with a welder should to be able to patch that up for you!
It looks so minimal!
You're so square
Baby I don't care
PostPosted: Wed Jun 01, 2011 10:11 pm
I don't know anyone with a welder... and I don't know how to weld.
Im sure there would be a local place that could do it for me.
PostPosted: Wed Jun 01, 2011 10:37 pm
If you have a good relationship with your mini mechanic i'm sure they would zip it up in a few minutes for you?
If not, someone on here must live near by, come on guys!
You're so square
Baby I don't care
PostPosted: Thu Jun 02, 2011 7:11 am
I don't have a mini mechanic so I was kind of hoping someone with welding skills could give me a hand.
Else on Saturday I will drive around to the local businesses.
The metal is about a mil thick. I would need a patch which is about 2 inches by 1 inch.
PostPosted: Thu Jun 02, 2011 8:29 am
Got any Smash repair shops nearby, they should be able to sort it out for you.
PostPosted: Thu Jun 02, 2011 8:35 am
Yeah, that's the sort of place I was going to try.
I'd just hope that I don't get a cowboy who stuffs up the metal.
PostPosted: Thu Jun 02, 2011 10:29 am
Just patch it with bog. You've got all the rust out and its not structural.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Thu Jun 02, 2011 11:03 am
As Yoda once told me: "Apply filler thinly you must. Steel is good, and strooong."
I'd rather have this fixed and not patched.
Users browsing this forum: No registered users and 67 guests
