It is currently Mon Jul 21, 2025 11:41 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jun 05, 2011 9:54 pm
It is many years so I had forgotten that the PJ and UJ use different output shafts (one retained by a bolt the other by circlip).
However I think you'll find the splines are common as I have seen a rod change box with rubber unis - they just sort of float about.. but do work...
When I decided my S UJs were getting too tired I asked my local BMC expert for advice. His response was that I should find the newest rod box I could get my hands on and steal the appropriate parts. They're still these 20+years and 100K miles later.... I think there might have been some new balls at one point but can't be sure.
Cheers, Ian
PostPosted: Mon Jun 06, 2011 4:56 pm
The change point for the Pot joints was not the introduction of the rod-change box.
The first rod change boxes used rubber cross joints.
The out-put shafts are very different. I can not imagine that it would be possible to fit a pot joint to the earlier type even if the spline was the same.
PostPosted: Mon Jun 06, 2011 8:57 pm
You're right, they're quite different but still interchangeable. Both yoke sections just slide up and down the splines but not enough to actually fall off. The end of the drive shaft/output shaft sort of bump up against the rubber crosspiece and this stops things sliding too far.
I only drove the car about 20 feet (onto the trailer) but dodgy joints were the least of this car's problems...
BTW Bill's advice re the newest box I could find was not directed at getting any particular "version" but just having bits with the least wear...
Cheers, Ian
Users browsing this forum: Steam and 84 guests
