It is currently Sun Aug 17, 2025 1:29 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 245, 246, 247, 248, 249, 250, 251 ... 568  Next
PostPosted: Mon Jun 06, 2011 7:21 pm
Attempted to tune the carb. Realised I had absolutely no idea what I was doing and put away the screwdriver.
'77 Leyland Mini Van
PostPosted: Mon Jun 06, 2011 10:36 pm
hahaha
 Post subject: Playing Roller rockers.
PostPosted: Tue Jun 07, 2011 5:19 am
Spent a couple of hours assembling a set of Roller rockers using correct spacers and washers to get alignment correct with Valve tip. I have used a set of Purple/Pink coloured ones. Not as good as the Titan ones I have on my speedway car.
"Let us remove your "SHORTS"
PostPosted: Tue Jun 07, 2011 9:24 am
last night I fixed my choke cable, and took my roof rack off - f*ck me that little car is fast
PostPosted: Tue Jun 07, 2011 6:43 pm
Visited the mini in the spray shop and removed it from the rotisserie and mounted onto the new trolley I made over the past few days.
The guys were workiing on the doors today doing the boring rubbing of the highfill in prep for the colour. The excitement builds.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Jun 07, 2011 7:03 pm
Mind if i ask how it supports on the rear?
After much studying of a mini body and measuring I decided to make the trolley bolt onto the existing subframe mounting points.
The front uprights fit into the tower holes and bolt as per front subframe and the rear is made to mount to the front points for the rear subframe.
I guess the only issue I now have is how to remove the trolley fit the subframes and that will be the next challenge. I did make the trolley to bolt at the 4 corners so it can be broken down into 4 pieces.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Jun 07, 2011 8:39 pm
i wrote an essay in about my mini for my y9 italian exam, got carried away an missed the other half of the exam :S
PostPosted: Tue Jun 07, 2011 10:10 pm
Ha you don't need no learning, school's for suckers :lol:
PostPosted: Wed Jun 08, 2011 12:24 pm
Tell my teachers that :roll: :roll: Half of them are stoners or Alchoholics, oh and the Pedo coordinator
PostPosted: Wed Jun 08, 2011 1:19 pm
Milatsmadmini
Just finished the 5minute job of installing a PCV to the mokes engine :)
Now have no idea how to tune it!!! :lol: :lol: :lol:
its only going to one port.... do i bother splitting it into both ports?
PostPosted: Wed Jun 08, 2011 1:44 pm
if it's a weber, then yes.
PostPosted: Wed Jun 08, 2011 3:50 pm
Had a great day @ Cooper works!
Installed a MKI heater (oh yeah baby)
Installed the airhorns (get out of my way)
Connected the washer bottle
Changed Steering wheel (larger 14" wheel is sensational to drive with, just like power steering!)
Looking forward to taking the little bugger out for a spin!
1970 Cooper'd K
by "Cooper Works"
PostPosted: Wed Jun 08, 2011 7:32 pm
I have split mine to both ports, but it's not really necessary. I ran for years with it into 1 port only, I just richened the idle mix 1/2 a turn on that side only. No worries...
PostPosted: Wed Jun 08, 2011 9:48 pm
Did more cleaning of the clubby and wired up the 6x9s in prep for hay.
Woot 3 days :P
-Motor mechanic - Proud owner of a '76 Clubman S and a Ford ef xr6 manual :P
PostPosted: Wed Jun 08, 2011 10:59 pm
Welding, grinding...
;-) Pete...
____________________
1968 Deluxe 1275
1969 Deluxe 'Scruby' 998 Looking for a roof skin...
