It is currently Sun Aug 17, 2025 5:56 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 247, 248, 249, 250, 251, 252, 253 ... 568  Next
PostPosted: Sat Jun 11, 2011 8:58 pm
Removed my carby and pulled it into a million pieces. Have started cleaning said pieces. Tomorrow I will try and reassemble it. I wish I knew what I was doing, but that's the fun!
'77 Leyland Mini Van
PostPosted: Sat Jun 11, 2011 9:01 pm
Had a bit of a poke around plotting plumbing for the brake booster.
PostPosted: Mon Jun 13, 2011 6:12 pm
Replaced clutch m/c clevis pin.....luckily P.O. had put an R pin instead of split :D
Bolted up the front bumper properly so no more (or at least less) rattles :D
Rebuilt one carb with one to go. Not much wear or problems, but both carbs were a bit loose on the manifold! Maybe cause of my problems with bad low throttle running (delrin is still on piston) :?
All in all a productive arvo!
Cooper S Mk2
Cooper S Mk1
PostPosted: Mon Jun 13, 2011 6:34 pm
Played with the wiring -plugging the loom together - spent nearly an hour getting the screws out of the firewall where the centre binnacle attaches :evil: now can't get the new screws back in – will need to run a tap though them me thinks.
David L
PostPosted: Mon Jun 13, 2011 6:46 pm
Cleaned the rod type gear lever assembly and reassembled and cleaned the Carby and still trying to work out how it all goes back together. :?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Jun 13, 2011 7:01 pm
Spent a few hours lying under the shell with a heat gun and scraper getting the under-body goop off. Only got about 1/2 done before my noodle arms gave out.
Also sorted some boxes of old parts. I have so many that I know I won't use but don't want to throw in case they are wanted by someone. Like 4 different types of mechanical fuel pump.
M
PostPosted: Mon Jun 13, 2011 7:43 pm
I put my first carby together immediately after dismantling it with help from Gregory's and Mini resto manual so I didn't forget anything. If I tried tomorrow (or next weekend) I would forget something for sure!
Just gotta remember to stick some ATX in the piston damper hole!
Cooper S Mk2
Cooper S Mk1
PostPosted: Mon Jun 13, 2011 7:45 pm
Drove home from another great weekend in Hay. Car was trouble free all weekend. Thinking of next year already. Thanks everyone who made it such a great time.
Why don't people believe me when I say Arianca Tan will make a come back.
PostPosted: Mon Jun 13, 2011 8:06 pm
Refurbed a set of Cooper S carbies, new spindles, bushes & butterflies, new needles and jet tubes, new needle & seats, new heat shield, all bead blasted, just like new. Only been in pieces since February last year!
Stripped the DCOE Weber off the race car for new kit & gaskets, soft mounts etc. Also stripped the alternator, alloy housing was a bit crusty, bead blast will clean that up.
Steve
PostPosted: Mon Jun 13, 2011 9:52 pm
nothing today, but yesterday I had glorious fun in it at Hay :D
PostPosted: Mon Jun 13, 2011 10:53 pm
Fixed up the interior light (but not the door switches) and stuffed around with the headlights too. Looks like the dimmer foot switch is stuffed so I need to add that to my list.
1970 Mini K
PostPosted: Mon Jun 13, 2011 10:55 pm
it's probably stuffed because the headlights melted it (like mine a few years ago), so add some headlight relays to the list as well
PostPosted: Mon Jun 13, 2011 10:59 pm
cleaned the garage and assembled the engine crane. looked forlornly at the bearings I got from simonk and realised that they were not getting in this weekend after all :(
PostPosted: Tue Jun 14, 2011 4:53 pm
Finally did some work on the mini, got the engine all ready to be pulled out. just need to borrow a mates engine hoist.
This is the first time ive pulled just the engine, i usually lift the shell off the subframe.
Can i get the engine out with the radiator still attached?
PostPosted: Tue Jun 14, 2011 4:58 pm
yep, no worries - but if you care about the paint on your drivers side inner guard, put a blanket or something over it in case the motor swings to that side
Users browsing this forum: No registered users and 391 guests
