It is currently Fri Aug 22, 2025 12:59 pm
 Post subject: 850 sport twin SU's???
PostPosted: Mon Jun 13, 2011 1:27 pm
Hi All
Below is a pair of (from what I have been told) two right hand 1 1/4 SU's on a Peter Manton manifold for a 850 sport
Could someone please confirm if they are genuine?
PostPosted: Mon Jun 13, 2011 1:44 pm
PostPosted: Mon Jun 13, 2011 8:54 pm
thanks 74snall but do you have a close up photo, I can see you have 2 right hand carbs but cannot see the manifold, looks a similar setup
PostPosted: Mon Jun 13, 2011 9:06 pm
I picked up a set very simular earlier this year.
http://ausmini.com/forums/viewtopic.php?t=69080
PostPosted: Mon Jun 13, 2011 9:17 pm
Monda
They (looking at the stickers on the air filters) are the Monaro Motors (NSW) version of the Sports 850 carbs. References I've heard are they are two "left" hand carby's, which is correct in your picture, but you look from the back, not the front.
I've got the Manton set with the Peter Manton cast into the manifold. The ribbed casting looks similar but I can only presume Monaro motors used a blue label on the flat spot of the manifold.
"Sports850" on this forum has studied these models. He'll pop up soon.
Alex.
PostPosted: Mon Jun 13, 2011 9:18 pm
This is the same car but closer. Manifold seems to look the similar to yours.
PostPosted: Mon Jun 13, 2011 9:33 pm
we should wait for sports850, but his internet access is patchy so he doesn't get on much
I've seen a few sets of double left hander twins on cars, it was probably a fairly common DIY mod as well as the actual manton/s850 ones.
the choke linkage poking up at the at top of your first picture is unusual, and matches phillb's photo, as does the throttle cable bracket
PostPosted: Mon Jun 13, 2011 9:41 pm
nice one guys, thats a great help, looking promising, they came off a vic registered 850 (non sports) it was missing the sticker on the manifold which I think confirmed it as a peter manton manifold, just want confirmation
PostPosted: Mon Jun 13, 2011 9:45 pm
just don't be too disappointed if they're not the genuine article...
I reckon comparing the choke linkage will be the key to it. The non-genuine ones I've seen have used a twin core choke cable with one core going to each carb - the one in phillb's appears to have some sort of linkage from below (?)
PostPosted: Mon Jun 13, 2011 9:48 pm
As I said before, I used to tune a genuine one in the 60s.
Choke operated on 1 carb only, there was no linkage between them.
PostPosted: Mon Jun 13, 2011 9:50 pm
oh!!
well that explains why I can't figure out the choke linkage
PostPosted: Mon Jun 13, 2011 9:58 pm
Ok will try and get a few more photos up in the next few days, may help cheers
PostPosted: Wed Jun 15, 2011 8:16 am
Like my set? 8)
PostPosted: Thu Jun 16, 2011 11:48 am
There were kits available from Manton, BMC, Warneford and others that all used the same bits.
I have some manifolds that are all the same except for the riveted on plate.
Warneford (Automotive Carburettor Company) would have made the kits for all of them.
PostPosted: Sat Jun 18, 2011 3:54 pm
OK, below are a few more pics of the linkage as requested, I pulled these apart about
10 years ago and not 100% sure if I put them back the same way, I also have a few extra linkages and brackets could be off the twins or other single carbs??
