It is currently Tue Aug 19, 2025 11:04 am
 Post subject: new motor specs
PostPosted: Thu Jun 16, 2011 4:48 pm
Resident Haemorrhoid
Okay so i am looking at rebuilding my 1098 as it has a bloody big gouge in it
so i have the following items
HS4 carbie and heated manifold
12G202 head
LCB extractors onto a RC40 spots exhaust
pulsar dizzy
what would you guys recommend i throw at it, cam etc for a good sporty motor??
mtsmini wrote:
Tombo wrote:
PostPosted: Thu Jun 16, 2011 4:54 pm
Get someone to show you how, or get them to port your head a bit
A GR cam grind, not sure which would best suit your setup, but one will be very helpful
You're so square
Baby I don't care
PostPosted: Thu Jun 16, 2011 5:20 pm
I am in the same predicament, but I will wait to see how this topic develops before I think about starting my own :!:
PostPosted: Thu Jun 16, 2011 5:25 pm
no worries you could be waiting a while it took me 3 months to summon the courage to pull the motor out :wink: :lol:
mtsmini wrote:
Tombo wrote:
PostPosted: Thu Jun 16, 2011 5:48 pm
I suppose the age old question is how much do you want to spend?
I recently freshend my motor up and added some goodies but it ended up more than double what i expected to spend.
What sort of driving will you be doing with it?
Jason 8)
PostPosted: Thu Jun 16, 2011 6:06 pm
mainly a daily drive with some occasional spirited driving :wink:
mtsmini wrote:
Tombo wrote:
PostPosted: Thu Jun 16, 2011 6:10 pm
From what I have been reading up this afternoon, the RE13 camshaft certainly seems to be the one to go for.
There is reference to a RE83 also, but I am not sure if this is a typo or if it's a totally different cam.
PostPosted: Thu Jun 16, 2011 6:24 pm
In my opinion, a RE13 is going to be too much for 1098 daily. Maybe the RE83 is the better choice.
Every time this topic comes up, the best advice that people give, is to call Graham Russell and ask him what he thinks. HE will give you an honest answer and he knows what works.
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Thu Jun 16, 2011 6:27 pm
Send a PM to DrMini and ask what he would recommend.
PostPosted: Thu Jun 16, 2011 6:32 pm
Milatsmadmini
Ryan
Best advice so far!
Ive got a warm 1152 with an RE13... takes a bit to get to cam... sings all the way to 7k though ;)
PostPosted: Thu Jun 16, 2011 6:43 pm
The block's gouged so it needs an over bore then. Will you go for the minimum bore or do you want to go BIG :?:
Either way the rebore will cost about the same and the larger pistons will also be about the same cost, (obviously they will be slightly more expensive) but I reckon it will be worth it.
PostPosted: Thu Jun 16, 2011 7:29 pm
:idea: Bin the 1100 and warm over a 998 Gadgets :wink: :D
PostPosted: Thu Jun 16, 2011 7:41 pm
does 100cc less make a big difference???
mtsmini wrote:
Tombo wrote:
PostPosted: Thu Jun 16, 2011 7:49 pm
1100's have plenty more torque down low but don't like to rev as hard.
998's don't have the low down torque, but make for it top end as they don't mind to rev.
It's all down to the squareness of the stroke.
PostPosted: Thu Jun 16, 2011 7:50 pm
12G what head? Its the numbers after the 12G that count!
Go the 1098 over the 998 for a roady unless you want a certain type of motor, make sure you get your crank crack tested.
Jacob
Users browsing this forum: No registered users and 272 guests
