It is currently Sun Aug 24, 2025 1:15 am
 Post subject: While I'm down here
PostPosted: Thu Jun 16, 2011 6:45 pm
Howdy Team.
I've just got my mini back from the panelbeater. She's all rust free, straight and shiny. Now it's time to launch into building it back into a proper car. I'm going to be crawling under it to put in new suspension and brakes (see list below).
Is there anything else I should look for/check/replace while I've got the car stripped out and up on stands with the engine out? (Steering, subframes etc)
Here's what I'm putting in:
Front brakes:
* Mini Sport 8.4" Vented 4 Pot Alloy Brake Calipers - anodised in the colour of your choice
* Mini Sport 8.4" Vented Grooved brake discs
* Drive Flanges
* Brake Pads and split pins
* CV Joints and boot kits
* Steering Arms
* Swivel Hubs
* Ball Joints
* Taper Roller Wheel Bearings
* Wheel Studs
Back brakes:
* Back Plates
* Wheel Cylinders
* Brake Shoes
* Handbrake Levers
* Rubber boots
* Adjusting wedge screw
* Tappets
* Return springs
* Brake drums with spacer
* 55mm Wheels studs
Suspension:
1 x set of 4 Spax gas shock absorbers.
1 x Mini Sport Adjusta Ride Kit
1 x Mini Sport Adjustable Tie Rods
1 x Mini Sport 1.5° Negative Camber Bottom Arms
1 x set of 4 poly bottom arm bushes
1 x set of 4 poly tie rod bushes
Any help and suggestions welcomed.
Thanks
Cheers, Matt
Don't be fooled, Gruhms is not my real name.
PostPosted: Thu Jun 16, 2011 9:02 pm
I got an email saying I had a reply to this topic, but I don't see any. When I clicked the link in the email it said the reply doesn't exist.
Can anyone make sense of that for me?
Cheers, Matt
PostPosted: Thu Jun 16, 2011 9:16 pm
Someone may have made a post and then deleted it for what ever reason.
Maybe :?
Image Image
PostPosted: Thu Jun 16, 2011 9:18 pm
There was a reply but the poster deleted it.
Don't forget to fit new rubber hoses to the brakes.
PostPosted: Thu Jun 16, 2011 9:42 pm
Just remember to fit all your battery, brake and fuel lines before the subframes go in :wink:
PostPosted: Thu Jun 16, 2011 9:48 pm
Clutch hose as well. If you get the four brake hoses, for the same or a little cheaper you can get a brake line kit which has the clutch hose included in the bag.
PostPosted: Thu Jun 16, 2011 11:08 pm
get your rack looked at. PITA when in situ but while engine and subby out do it..and also clean the engine bay and sort the wiring
PostPosted: Fri Jun 17, 2011 5:56 pm
Sorry, I should've been more specific. The subframes are still in place. It was painted as a rolling shell. Is there anything I can look at to do with the steering rack while the subframes are still in?
Thanks for the advice. I'll definitely look at doing the brake and clutch hoses.
Cheers, Matt
PostPosted: Fri Jun 17, 2011 7:23 pm
To get the rack out you need to remove all 4 subby bolts in the floor, and the 4 in the towers (or remove the nuts if it has studs there). Also loosen the 2 front bolts a few turns. You can then tilt the subby down enough to get the rack out.
Before refitting the rack try the 2 U-bolts in the floor holes. You will find they have stretched too wide, so put them in a vice and squeeze closed until they fit.
PostPosted: Fri Jun 17, 2011 7:53 pm
other things I will suggest is a new front wiring loom and replace all suspension rubbers and engine stabilizer rubber
Gear linkages
PostPosted: Sat Jun 18, 2011 8:17 am
Thanks again team.
I'll be putting a whole new wiring loom in because the old multi-coloured spaghetti was shocking.
There has been some mixed opinions amongst others I have spoken to about the suspension and brake parts I got from Minisport in the UK. Some have advised me to sell most of it and get other stuff. Some have even said that it won't meet ADR regulations. As I'm new to all this, I just want more opinions.
I'm running out of money and time, so to sell what I've got and buy better would be a major setback. Is what I've got OK? What should I do?
I was planning on getting stuck into fitting it all this weekend!
Help please!
Cheers, Matt
PostPosted: Sat Jun 18, 2011 3:32 pm
What wont meet ADR's? Kinda interested because i'm thinking of buying something similar.
1978 Leyland Clubman S
PostPosted: Sat Jun 18, 2011 3:43 pm
Are any replacement parts ADR compliant?
Were new parts from Leyland ADR compliant?
Are there any ADRs on replacement parts anyway?
Me thinks someone is talking crap. (maybe more than one)
PostPosted: Sat Jun 18, 2011 6:50 pm
apparently braided brake lines are a no-no unless they have a yellow tag, but what parts do you have that you're concerned about?
PostPosted: Sun Jun 19, 2011 8:01 am
I don't know specifically. I didn't think there'd be any problems with any of it. I don't have braided hoses (but I do like the look of them). There have just been comments when I mention the parts I have, that some people think they might not meet ADR specs.
Sorry I can't be any more specific than that at this stage. I'm trying to find out more specifically what the problem might be.
Has anyone else had many dealings with UK Minisport? Is the quality of their parts something I should be concerned about?
Thanks for all your help.
Cheers, Matt
