It is currently Fri Jul 18, 2025 2:27 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Apr 13, 2005 6:40 pm
You must throw some paint over the undercoat.
Undercoat absorbs water and in the tropical climate of the Blue Mountains it will start to rust under the undercoat.
If you leave it by the time you get all the dents out of the car you will need a new car!
I moved from the Blue Mountains to Goulburn. I don't have to worry about rust. I can leave it bare metal and it don't rust!
PostPosted: Wed Apr 13, 2005 7:07 pm
i dont have that many dents :shock: yeh ill put some gray paint on it aswell
PostPosted: Thu Apr 14, 2005 1:26 am
benjamin wrote:
just going to undercoat it for now and once the car has all the dints removed i will buy a spray gun and do it myself. i already got a supercheap air commpresser
Don't leave it in undercoat to long as it is porous and surface rust will start. Best to get a can of spray paint and cover it.
Chris
Everything I like is either
PostPosted: Thu Apr 14, 2005 8:14 am
And then when you have finished all that, I have a shell you can strip back, get straight and undercoat for me too... :wink:
PostPosted: Thu Apr 14, 2005 9:15 am
Now you have got this far you may as well get some colour matched and spray the area for the time being. Just be careful with your masking you don't want any hard edges. I resprayed the back of mine with an air brush, my dent was a lot bigger than yours (the light pointed in a different direction), and now, after a few tins of bog and a lick of paint, you'd hardly notice!
PostPosted: Thu Apr 14, 2005 10:47 am
sanded back to 1200 them undercoated
PostPosted: Fri Apr 15, 2005 3:12 pm
while the tank is out i thought id paint it so i sanded it back to bare metal and bought some black paint what should i do to stop the black scratching off easy
PostPosted: Fri Apr 15, 2005 11:22 pm
hers my last update so tell me what you think im gonna give it one more coat tommorow and then put it all back together but here is what i did tday
PostPosted: Fri Apr 15, 2005 11:28 pm
Benny my boy that looks like new (from the pics) one question though ....how much bog did you end up using?
but that looks f***ing awsome
Pat
_______________________________________________
Team MADMAN/Pat Rogers
PostPosted: Fri Apr 15, 2005 11:35 pm
Pat
not very much, i panel beated it out but because my panel beating skill are terrible i couldnt get it perfectly flat so the bog was just to smooth it out a bit, ill take a pic of the inside if you want and you can see that i didnt just bog up the dint, i used as least as possible
PostPosted: Sat Apr 16, 2005 1:02 am
good work ben,
the paint matching seems seamless too
cant tell the diff
Inconspicuously Conspicuous
