It is currently Sat Aug 23, 2025 1:34 am
 Post subject: Dizzy rotor pozzy
PostPosted: Sat Jun 18, 2011 9:47 pm
So, is it bad if my dizzy is firing no.1 at about 5 o'clock?
All the posts I've read on here in my searches seem to suggest 2 o'clock is usually about right. She starts alright but she's running pretty rough, putt-putt-putting no matter how I set the timing.
Here's the dizzy which I assume is the original:
'77 Leyland Mini Van
PostPosted: Sat Jun 18, 2011 10:23 pm
Just means the dizzy drive shaft (or drive dog) is 180° out. You can change it around and move the leads 180° to make the purists happy, but it won't go any better. :wink:
PostPosted: Sat Jun 18, 2011 10:30 pm
Thanks! I thought it might be that, it was just the fact it's at 5 instead of 8 o'clock that had me wondering!
PostPosted: Sun Jun 19, 2011 9:02 am
Means you can sleep in for another 3 hours :roll:
David L
PostPosted: Sun Jun 19, 2011 9:54 am
Running rough after you re-did the timing leaves plugs, points, leads and finally coil for eliminating electrical/bad spark causes.
Unless it's a mixture-related putt putt putting? Had a play with the carb yet?
PostPosted: Sun Jun 19, 2011 3:31 pm
Tomorrow's job is to have another play with the mixture. New coil so it shouldn't be that. I'll try a new set of plugs tomorrow as well. I'm getting spark at each of the plugs. I've just cleaned the carb last weekend as well so maybe there's a vacuum leak somewhere? All things I still have to look at!
Users browsing this forum: Bing [Bot] and 295 guests
