It is currently Sat Aug 02, 2025 9:27 pm
 Post subject: Steering rack
PostPosted: Sat Jun 25, 2011 9:18 am
I have a spare steering rack sitting hear that was out of a roundy if I rebuild it would it fit into one of my mokes
Don't under estimate the power of a Mini
1975 Supercharged Blue Mokezilla ;)
1976 Fudge Moke
1967 BRG & White 67 Morris Deluxe
1974 Clubman Mini S
2005 Red Mini Cooper S
2009 Mitsubishi Outlander VRX
PostPosted: Sat Jun 25, 2011 12:52 pm
Mods rock!
It is only worth doing if it is an Ozzy made rack. Have a look on the LH end and it will say something like CAM GEARS made in oz etc, if it doesn't say that, bin it.
You'd also be hard pressed getting parts for the UK racks.
PostPosted: Sat Jun 25, 2011 3:11 pm
The Cam Gears Oz ones I rebuild for late bigwheel Mokes, I put Morris 1100 tierods on them. This gives a bit more thread engagement into the tierod ends.
PostPosted: Sun Jun 26, 2011 8:50 am
It is a cam gears rack but what is the difference between the two ius the aust rack stronger?
1976 Fudge Moke
1974 Clubman Mini S
PostPosted: Sun Jun 26, 2011 10:44 am
Would it be beneficial to get a 2.2 turn rack?
Could you change the Aust. to a quick rack?
1978 Leyland Clubman S
PostPosted: Sun Jun 26, 2011 1:10 pm
Is there a "how to" for steering rack rebuild as I am having trouble getting the steel coller out of the end of the rack without distroying it I assume thaty I will need to re use it
1976 Fudge Moke
1974 Clubman Mini S
PostPosted: Sun Jun 26, 2011 2:05 pm
Mods rock!
PM sent :wink:
PostPosted: Sun Jun 26, 2011 3:31 pm
just drill it - they're cheap
PostPosted: Sun Jun 26, 2011 7:08 pm
You can often refit these lock collars to the other end, provided the original punched in spots are well away from the slots. If not, keep it for another rack and fit another s/h collar, or a new one.
I machine the punched in bit inside the machined down part back to original diameter so they don't bruise the rack threads when refitting, and I toss them away once used twice.
PostPosted: Sun Jun 26, 2011 7:45 pm
I want to reuse this coller but it is being a pain to remove :evil:
1976 Fudge Moke
1974 Clubman Mini S
PostPosted: Sun Jun 26, 2011 7:49 pm
Mods rock!
Did you receive my email?
PostPosted: Sun Jun 26, 2011 7:52 pm
I drill into the hole with a 6mm drill. Hold the drill running while then turning the collar to and for a bit with multigrips- the drill bit mills the bent bit of the collar away, then it will spin off easy. :P
PostPosted: Sun Jun 26, 2011 9:40 pm
Yes I did and I think that I have to make up a special tool. Triing to use what I have isn't working
1976 Fudge Moke
1974 Clubman Mini S
PostPosted: Tue Jul 26, 2011 4:10 pm
Worthwhile?
Race/hillclimb only??
PostPosted: Tue Jul 26, 2011 8:08 pm
The Australian made Cam Gears rack (the rack inside it) is a bigger diameter than the UK ones.
It is actually a short version of the Morris 1100 rack.
The UK ones are throw away now, most wear parts are unobtainable. And their recent new ones are poorly made, (probably not in UK) :cry:
