It is currently Sun Aug 17, 2025 11:59 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 251, 252, 253, 254, 255, 256, 257 ... 568  Next
PostPosted: Sat Jun 25, 2011 5:07 pm
Can't fit the ram tubes, let alone an air filter on it..
Plus, i need the money!
I'll just have to build a supercharged motor for next july instead ;)
You're so square
Baby I don't care
PostPosted: Sat Jun 25, 2011 5:14 pm
Awww thats SAD....
DVS K
Toad the Moke
Brutus the Ute
Mean Monster
Purple People Eater
PostPosted: Sat Jun 25, 2011 5:18 pm
Got stuck into making a new home for the Moke project and any other paddock find that may turn up.
Worked out it would be cheaper to create level areas under the house than build a shed. Today was stage one - major retaining wall
David L
PostPosted: Sat Jun 25, 2011 8:34 pm
Give Ash some flowers Nick .
I'm currently part way through giving Tadhg a head job ( :P :lol: ) after his car had a BHG. I think I've worked out the problem, head is bent 0.006". So it has to go to the machine shop before we can put it back on.
PostPosted: Sat Jun 25, 2011 9:08 pm
Picked up the body from the paint shop. :) :)
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Jun 25, 2011 9:26 pm
picked up my 1400.
:D
PostPosted: Sat Jun 25, 2011 9:37 pm
Woah, it's very pearly
You're so square
Baby I don't care
PostPosted: Sat Jun 25, 2011 11:10 pm
Took the head off. Thanks 1018cc for your help, knowledge, garage. 8)
Why'd we take the head off? Driving home from dropping the boy at school yesterday, I revved it hard in first, it went bang, and started sounding like a mower. :x :( So the immediate thought was head gasket. Got it home (very, very slowly), Nick suggested using DrMini's individually calibrated compression tester (i.e. a thumb, this time with a wet rag over it), and there was very little compression in cylinder 2. Removing the plug from cylinder 2 also showed no difference in sound (i.e. it didn't suddenly drop a cylinder). :roll:
So, we pulled the head today. This was informative. The gasket was intact. :? The metal between cylinders 2 and 3 was blackened, though. And Nick's since discovered that the head's 0.006" (roughly) out of straight... :( 0.006" high in the middle. :(
Other things that we found? Well, I now know that my engine is a 1303 (0.030" overbore). There's still honing marks on the bores. :o I've got 1.401" inlets, 1.151" exhaust (maybe it's 1.156", we were using a plastic vernier and it was by the light of the flouro!), with hardened inserts. The head is massively ported, the chambers significantly shaped. :o All very good news.
And the biggest discovery? The quantity of coke in the engine. :shock: I have photos that are scary! Layers and layers and layers of coke, on the pistons, throughout the chambers, all up the exhaust port... Even caked on the back of the inlet valves! :shock: :shock: :shock: Caked rather thick - there were sections on the pistons that I would've put at 1mm or more thick! :shock:
When this thing goes back together, it should run much, much better. It might well not run on anymore, given the engine will be quite a bit cooler internally... :)
And maybe one day I'll get around to finding a pair of twin HS4's... The HS2's are definitely the limiting factor on this engine. Ported head, decent valves, reshaped combustion chambers, big extractors... Intake breathing's the weakest link. :)
PostPosted: Sat Jun 25, 2011 11:11 pm
Wow. Sexy-lookin'.
I got mine running smoothly and was able to drive it around the block for the first time! :D And then a second, third and fourth time. And then I wasn't allowed out again :(
EDIT: Bad tags.
'77 Leyland Mini Van
PostPosted: Sun Jun 26, 2011 8:15 am
Took Morris to http://www.fhrxstudios.com/ charity BBQ / tuning & audition day. Was good to see some of the sound systems these guys have and the amount of money they put in just to listen to music.
What we spend on getting a few more HP they spend on Amps or speakers
Had three guys participially interested in a Mini and of course i directed them here
PostPosted: Sun Jun 26, 2011 8:35 am
Bought my speakers and board for under the back seat.
Time for tunes!
While I have the carpet out, to dynamat or not to dynamat that is the question :roll:
1970 Cooper'd K
by "Cooper Works"
PostPosted: Sun Jun 26, 2011 5:06 pm
Drove my car for the first time in a month!!!!!!! rebuilt the carbs and couldn't get the bloody car to start - the carbs were in really good nick - no wear but replaced all the bits and gaskets.
So...... checked the distributor which I hadn't been able to get off as bottom clip jammed against oil cooler
:x
finally got it off and points were not so good, cap was worn inside at contacts (but was probably pretty old as was marked "Lucas Australia") and the coil lead was corroded into the cap - wouldn't be surprised if also original as coil was dated 9/69!
Replaced points, condenser, and pinched a coil off my other car and tried for ages to start it. Ended up getting it going and runs much better - might just get new plug leads to really get it smooth....
Amazing it ran so well and reliably for the few years I had it! :D
Cooper S Mk2
Cooper S Mk1
PostPosted: Sun Jun 26, 2011 5:18 pm
I had the 850 out for a run today and had the excitement of both right rear pads let go of the shoe. Came home and got a set off the van to install and got the 850 home. Really annoying, this is the second time in four years and the 850 would only travel a maximum of 500klm each year. oh well, all is well. New shoes and springs all round. Thanks to Geebs for ya help, your a champion! While on the side of the road assesing the damage i had two seperate blokes come and have a chat who both had minis in the past. One guy was from NZ and spoke about hitting some cow crap and being sent into a spin in his mini. One of many stories he had, nice fella and made the chore alot bearable :D
PostPosted: Sun Jun 26, 2011 6:31 pm
appeased the minister for finance and recreation by painting a wall in our front room
PostPosted: Sun Jun 26, 2011 6:34 pm
Thought about my twinky moke..
/sigh/ :roll:
You're so square
Baby I don't care
Users browsing this forum: No registered users and 308 guests
