It is currently Tue Aug 19, 2025 1:13 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Jun 29, 2011 4:33 pm
STD drops proven to about 190 bhp with 153 ft lb torque
Run with straight cut gears.
Normal gears take about 120 bhp safely and 100ft lb torque.
Proven over and over on turbo minis, they all have huge power minis all run the clubman mini spares set and have no problems.
Just read around mate.
PostPosted: Wed Jun 29, 2011 4:44 pm
Are you saying that straight cuts are stronger than helicoil?
They arent because in straight cuts you only ever have 1 tooth engaged, with helicoil you have 1 1/2 (or 2 I cant remember) teeth engaged. Meaning Helicoil are stronger.
PostPosted: Wed Jun 29, 2011 6:00 pm
Are you saying that straight cuts are stronger than helical?
They arent because in straight cuts you only ever have 1 tooth engaged, with helicoil you have 1 1/2 (or 2 I cant remember) teeth engaged. Meaning Helical are stronger.... and they the teeth are longer making them stronger
Hehehehehe... :) fixed .... must of had something else on your mind :)
PostPosted: Wed Jun 29, 2011 6:14 pm
haha oops. Thanks, everyone knew what i meant :oops: :oops:
PostPosted: Wed Jun 29, 2011 6:17 pm
:lol: hahaha, no worries, I've got the worzcet speeling of anyone on hear so dont wurry :)
PostPosted: Wed Jun 29, 2011 7:12 pm
To further complicate this issue, yes straight cuts may only have 1 tooth engaged at a time, however they are usually/often of greater diametral pitch than helicals- ie. their teeth are bigger than the helical ones (but there's less of them). :lol:
PostPosted: Wed Jun 29, 2011 7:24 pm
:lol: this is also very true :lol:
PostPosted: Wed Jun 29, 2011 8:38 pm
so this is relevant towards the old "Which is stronger....unc or unf" argument?
mooo, I'm a pig!
PostPosted: Wed Jun 29, 2011 8:40 pm
Different arguments IMO.
That thread argument depends on what the bolt or stud is screwed into.
Alloy or other soft metals = UNC is stronger (less likely to strip out).
Steel or harder = UNF is stronger (more cross section below the thread).
PostPosted: Wed Jun 29, 2011 8:50 pm
gotcha!
mooo, I'm a pig!
Users browsing this forum: Bing [Bot] and 209 guests
