It is currently Thu Jul 24, 2025 10:06 am
PostPosted: Thu Apr 14, 2005 5:41 pm
Let's see now... My crank will have been at the heat-treaters for at least 10 weeks by the time I get it back. 10 weeks.
Man, you have to be patient. I just want my Mini back. :(
Jonathan
PostPosted: Thu Apr 14, 2005 7:21 pm
Who is the heat treater... is it in WA or elsewhere?
I'm tossing up whether to tuftride my 84.3mm stroker crank, after I wedge it.. I've heard good and bad reports on the process. Jury is still out.. :?
PostPosted: Thu Apr 14, 2005 7:24 pm
10 weeks? :shock: what's their excuse??
PostPosted: Thu Apr 14, 2005 7:51 pm
can someone explain "wedging"
im sure its been explained somewhere before, i just dont recall what it is
Inconspicuously Conspicuous
PostPosted: Thu Apr 14, 2005 8:05 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
it would be were i run up behind you grab ya undies and pull up hard :D
.... oh hang on thats a "wedgie"
makka
PostPosted: Thu Apr 14, 2005 8:10 pm
No it's not a wedgie... :lol:
On a 1275 crank, the counterweights are not really heavy enough for a good balance factor (OK there's another question.. for next time. :wink: )
Rather than weld 'em up to increase weight (not a great idea with most cranks) material (ie weight) is removed from the crankwebs, most on the side nearest the crankpin. This makes them look tapered, narrower at the crankpin side. So, relatively heavier at the counterweight opposite.
It also reduces rotating weight of the crank, raising its fundamental resonany frequency so less likely to crack (supposedly). And it will spin up faster....
It's all good. And I own a milling machine... 8)
PostPosted: Thu Apr 14, 2005 8:11 pm
Drmini you can have your crank nitrided. I have all of my race engine cranks either long or short stroke nitrided in sydney. But you will need to balance it first.
850 Morris Mini
Morris Mini Traveller
Mini sports Sedan
PostPosted: Thu Apr 14, 2005 8:15 pm
Can you nitride EN16 cranks (12G1505)? My S cranks (EN40B) are, but I was told (not on here) that nitriding won't work with EN16... :?:
Yes, I would balance it first, after I wedge it. :wink:
PostPosted: Thu Apr 14, 2005 8:22 pm
Yes you can. Nitriding has come a long way in the last few years.
850 Morris Mini
Mini sports Sedan
PostPosted: Thu Apr 14, 2005 8:24 pm
Also like what you have done with those honda brake conversions. Would like to have a better look at some one day.
850 Morris Mini
Mini sports Sedan
PostPosted: Thu Apr 14, 2005 8:37 pm
OK... I'm interested- who and where?? 8)
PostPosted: Thu Apr 14, 2005 8:50 pm
1) thanks doc, i understood all of it
2) is nitriding diffusing Nitrogen into the metal (like Case Hardening)
byt heating up and pumping with Nitrogen gas?
(that was my stab)
PostPosted: Thu Apr 14, 2005 8:52 pm
(that was my stab)
When I did metallurgy (eons ago..) yes.
But the depth is pretty shallow. Bloody hard, though!
PostPosted: Thu Apr 14, 2005 8:59 pm
I think they are called St George Heat treatment? I will find my paper work and send you a post. May take over the weekend before i find it, if thats ok.
850 Morris Mini
Mini sports Sedan
PostPosted: Thu Apr 14, 2005 9:03 pm
No problem.
My crank was stroked by Spiro, at St George Crankshafts, maybe related.. :?:
he's just around the corner where I work.. :lol:
Users browsing this forum: No registered users and 115 guests
