It is currently Sat Jul 19, 2025 6:49 pm
PostPosted: Sat Jul 09, 2011 12:10 pm
What would be the best way to remove the many small dints in the grill? Is it difficult to do (properly)?
Thanks in advance.......
Cooper S Mk2
Cooper S Mk1
PostPosted: Sat Jul 09, 2011 2:43 pm
Get a couple of grilles, take the rivets out, mix and match the slats until you have a full set of good ones, then rivet it back together.
PostPosted: Sat Jul 09, 2011 9:09 pm
I agree with DrMini.
BUT.. if you want to bang out some of the dents then start to look at how to use a slap stick aka slap file (it has many names).
Remove the rivets first (obviously) and then you can attack each of the slats. It does take some time.
I started repairing mine but I think it best just to find some old ones and piece all of the good bits together.
Here's a PDF that you might find useful:
http://www.tachrev.com/JeffLilly/dent_repair.pdf
1966 Morris Mini Minor Saloon (Dot) - 1275 Auto - Mongrel
1968 Morris Mini Van (Ivan) - 998 Auto - Mongrel
1968 Morris Mini.Matic (George) - Original
1968 Morris Mini.Matic (Charlie) - Original
PostPosted: Sun Jul 10, 2011 10:15 am
Thanks guys!
2 different ways of doing it.Didn't think of no. 1!
Cooper S Mk2
Cooper S Mk1
PostPosted: Sun Jul 10, 2011 4:58 pm
I took mine to an old school electro plater and he fixed mine (when a 4wd backed into me) for $20- for 2 dented slats. I took the 2 damaged slats off first, came back good as new.
Flute - 68 MK I Cooper S
Member: VMCI #2474
