It is currently Mon Aug 18, 2025 2:35 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 256, 257, 258, 259, 260, 261, 262 ... 568  Next
PostPosted: Fri Jul 08, 2011 8:29 pm
LS1380 wrote:
Had another attempt to sort out the wiring on the Moke :(
Jeeezzz !!, that'd make your head hurt :shock: :lol:
PostPosted: Sat Jul 09, 2011 9:14 pm
I visited Link today. Got some bits and bobs.
As always Brian is always helpful.
I have ordered a new radiator, exhaust and hub caps.
1966 Morris Mini Minor Saloon (Dot) - 1275 Auto - Mongrel
1968 Morris Mini Van (Ivan) - 998 Auto - Mongrel
1968 Morris Mini.Matic (George) - Original
1968 Morris Mini.Matic (Charlie) - Original
PostPosted: Sun Jul 10, 2011 3:34 pm
cut out passangers floor.
I have now confirmed that I HATE the previous owner of my mini.
Such a relativly easy job made damned difficult by dickhole!
Common sence says that if you have to use a kilo of bog (give or take a little) and in most places have flat sheet welded in 3 layers thick, replace the friggin floor!!
mooo, I'm a pig!
PostPosted: Sun Jul 10, 2011 5:09 pm
shock horror! i actually did some work on the mini. almost got it running again but the two batteries i had lying around were sucked dry :( wont be til the weekend after next that i will get a chance to look at it again
PostPosted: Sun Jul 10, 2011 11:01 pm
I panel beated the floor of the blue shell. The right hand sill was sad so it took some big hits with the sledge hammer. Tapped out many smaller dents with a light hammer and dolly.
In the process I realised that the seat cross member, passenger side sill and engine bay cross member were all full of sand blasting sand.
With a combinaton of a vacuum and hammer drill set on hammer only acting on some steel plate, I got the sand to flow out of the gaps. I took well more than a kilo of sand out of the car.
The shell is now up on tall stands with no rear subframe and I've dound the boot floor welded-in section has not been painted at all. Same with inside of near rear beaver. :roll: :roll: Piss poor workmanship from the painters.
So, finally progress. It'll need some welding then paint on both sides of the floor skin.
M
PostPosted: Mon Jul 11, 2011 11:14 am
Today I think I'll go for a dri-
Oh.
PostPosted: Mon Jul 11, 2011 12:03 pm
Not house trained?
David L
PostPosted: Mon Jul 11, 2011 12:12 pm
Rub it's nose in it , :!: that'll learn it . :lol:
PostPosted: Mon Jul 11, 2011 1:02 pm
Changed the oil. Decided to give KMX a try. I'd previously been using penrite HPR30 without a problem besides the price. The HPR was only $14 for 4L.
How much oil does the mini take? Mine took 4.5L, previously I thought it took about 5L. Is something wrong?
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Mon Jul 11, 2011 1:09 pm
Did you change the oil filter?
PostPosted: Mon Jul 11, 2011 1:23 pm
You win the prize...........my used oil. I'm on holidays, obviously my brain isn't in gear.
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Mon Jul 11, 2011 1:52 pm
Glad i could help
PostPosted: Mon Jul 11, 2011 2:30 pm
Should take 5.5l to fill a mini properly, including filling the new filter
You're so square
Baby I don't care
PostPosted: Mon Jul 11, 2011 4:25 pm
After ruling out hydro bag/line failure (liquid didn't smell enough) and the radiator being full, we narrowed it down to the bottle of spare radiator fluid we keep in the rear passenger storage bin. I don't think I've ever been so happy to see fluid pouring out of the bottom of the GT!
PostPosted: Mon Jul 11, 2011 4:31 pm
Wowzers, I dont think my clubby had that many wires.
Either way I feel better about my wiring after seeing that. Thanks.
So... I'm Seifer
Users browsing this forum: No registered users and 301 guests
