MrFail wrote:
GT mowog wrote:
Mokesta wrote:
I think it goes into the rubber spring threaded part to plug the hole. Like late Mokes had an alloy buffer in there. It stops crap going down through the rubber cone and sitting between the alloy and the thread, corroding it and seizing it up. In dry old Oz and with a bit of never-seize, these are not required on our roads.
I had a jap-import Rover with a set on and all the alloy cones had a big flat plastic cap sealing off the end opposite to the threaded end. So I reckon this plug is for the rubber spring thread hole. That's why it is rear only.
Maybe?? I AM just guessing...
M
If it is, I'd be fitting them to the fronts
Yea, i was thinking the same thing.... whats the use on the rear???? if it seals up the fronts it'd be better wouldn't it as they sit upright. atleast the rears can drain on their side easy.
The only problem is getting them in there. You need to have the thread clear to fit the compessor tool in. The threads are so in-accessable that once it comes time to fit the plug, you won't be able to.
If that is where they fit on the rears, what's the point? They are not at all prong to water getting in there, they are horizonal and the thread is not needed on the rears.
Why not email them to find out.
