It is currently Mon Jul 21, 2025 3:30 pm
 Post subject: Tapping a thread .
PostPosted: Thu Jul 14, 2011 8:41 am
One of the bolt holes into my subframe where I'm putting in adjustable brackets is stripped. I was thinking bout tapping a larger thread into it? Anyone had this problem what size thread should I tap.
I believe the current thread is 5/16 UNF Fine.
PostPosted: Thu Jul 14, 2011 8:54 am
Online
If it's stripped, the hole is now 5/16".
This is the right size to tap out 3/8" UNC. You can then use a starter motor bolt like I did.
Grease the threads good when you bolt it up.
PostPosted: Thu Jul 14, 2011 9:24 am
5/16ths is the only UNF thread I know of you can do this, but you can tap it out 3/8 UNF and directly screw in a 5/16th UNF thread replacement (helicoil). You can buy them loose in bags of about 10 or 20 for cheap. You don't need a special helicoil tap as the threads per inch are the same for these two sizes.
Just be aware, if one thread is soft like cheese on those rear subframe captive nuts, then they're all the same.
PostPosted: Thu Jul 14, 2011 9:31 am
3/8 Unc or 3/8 Unf doc?
PostPosted: Thu Jul 14, 2011 11:26 am
Online
1. You don't want a helicoil in there, if anything rusts you will be in trouble.
2. A bigger coarse thread in there is less likely to strip again.
2. A 3/8 UNC tap is way cheaper than a helicoil kit.
:wink:
[edit] of course if you have a 3/8 UNF tap already I would tap it to that, fit a 3/8 UNF bolt and forgo the helicoil. :lol:
IMO helicoils are a last resort.. even in alloy.
PostPosted: Thu Jul 14, 2011 12:41 pm
I tapped a 3/8 UNF into one of mine - no worries, except it's hard to get a socket on it now because it's the one that sits closer to the subframe :roll:
PostPosted: Thu Jul 14, 2011 1:16 pm
Went around work picked up unc 3/8 taps. So I'll use that. Should be fun :)
PostPosted: Thu Jul 14, 2011 2:35 pm
find some cutting fluid too
not sure if you've tapped holes before, but if not, practice on some scrap, or a 5/16 nut held in a vice or something.
PostPosted: Thu Jul 14, 2011 3:26 pm
Yeh I should be alright. Just one thing most of the thread is stripped but should I run a 3/8 " drill bit through to clean it all up?
PostPosted: Thu Jul 14, 2011 3:45 pm
NO!!!!
but you can run a 5/16" drill bit through it
 Post subject: tapping a thread
PostPosted: Thu Jul 14, 2011 3:55 pm
Do yourself a favour and fit 3/8 UNC Allen head bolts . No more strugling wth sockets that wont fit in the space. Even 3/8 sockets are a tight fit. Fit a high tensile washer under the bolt head. Just make sure the thread doesnt go behond the captive nut. Spray Shell ensis fluid ( transformer oil) through the bolt holes - get as much in as you can to stop the dredded red powder comming again. Coat the thread of the bolt as well
Mk1 Cooper S
Mini K Rally car
PostPosted: Thu Jul 14, 2011 4:19 pm
Mods rock!
Depending which one it is, fitting a bigger bolt may make it harder to do toe in / out adjustments as there won't be any play left in the hole on the bracket.
I helicoil them back to original. No odd bolts then. All these threads (welded root nuts in the subframs and body) I always give the bolts a smear of grease on the threads.
PostPosted: Thu Jul 14, 2011 6:29 pm
simon k wrote:
NO!!!!
Lol just re read that ... Duh!
Got that all done just b4 it got dark ... Wish I had a garage / shed....
Working in a carpark sucks.
Users browsing this forum: drmini in aust, kirby and 84 guests
