It is currently Sat Jul 19, 2025 2:43 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Thu Apr 14, 2005 8:17 am
Chris that is a no re 10 thou cam bearings - I can only get them for small bore, don't know about 1275. Better find another cam and keep that one in your door bin to leave 248* indentations on peoples sculls :lol:
And to hijack the thread (you watch it I have a 260* cam here so no funny business!), has any one heard of small bore blocks coming standard with sleeves? Mine has them, I'm guessing they have been put in at a later date but I thought I'd check. The problem is, when I blew the hole in the cylinder head it also damaged the block - and the sleeves have seperated the tiniest amount from the block itself. Which is bad.
Anto.
PostPosted: Thu Apr 14, 2005 8:24 pm
small bore -.010" cam bearings DO fit a 1275. Been there, done that. On my boss's 1100S block. :wink:
Rear bush is shorter on small bore, but is the same length as the rear 1275 cam journal is. All cams are the same length, BTW... :wink:
PostPosted: Thu Apr 14, 2005 9:19 pm
chirs cant wait to hear more about the build as i sold the parts and would love nothin more than to see runnin. all the best. and i am setting up more 45dcoe so i will have a little bit on the cost and and it i get an improvement. i would also like to know an aproximate cost of porting, match porting,camber work and and a shave of the head if anyone knows
 Post subject: Sleeve....
PostPosted: Thu Apr 14, 2005 11:27 pm
Anto wrote:
And to hijack the thread (you watch it I have a 260* cam here so no funny business!), has any one heard of small bore blocks coming standard with sleeves? Mine has them, I'm guessing they have been put in at a later date but I thought I'd check. The problem is, when I blew the hole in the cylinder head it also damaged the block - and the sleeves have seperated the tiniest amount from the block itself. Which is bad. Anto.
Not unusual Anto....great way of reclaiming a block that has been overbored and worn out.
Now to hijack Chris thread...whats happening at Murrumbateman :!: Have you managed to get the car back home :?: Has Wayne rang about the 1100 engine possibilities :?: What :?: What are u up to :?:
PostPosted: Thu Apr 14, 2005 11:30 pm
A lot of motors (particularly 1275s) were sleeved at the factory due to casting or porosity problems. Faulty ones were put aside and then a bunch done as a production run. :wink:
Last edited by drmini in aust on Fri Apr 15, 2005 9:09 am, edited 1 time in total.
PostPosted: Fri Apr 15, 2005 8:38 am
It just seems strange to me to sleeve a small bore block instead of just grabbing another one from the back shed. I guess small bore blocks were valued way back when :) So possibly my block could have been crap at the factory, or has been bored out countless times afterwards.
Mick, cost of trailoring the car back from Murrumbateman and borrowing of trailor on Sunday was 1x case of VB :wink: So I have got it home, will be talking to Wayne this weekend. I'm not without transport though, the bike is registered and I'm riding that, and if my parents buy a new car on the weekend I get the 121 til the Mini is fixed. You can see the pleasure written across my face with that thought can't you.....
 Post subject: Beats walking....
PostPosted: Fri Apr 15, 2005 1:21 pm
Great news Anto....careful on the Bike tho :)
121? wheels is wheels...I have to chauffer around a daughter now because she had her Charade cleaned up...I thinks its a write off (kinks in the rear chassis rails) :evil:
Users browsing this forum: No registered users and 28 guests
