It is currently Fri Jul 18, 2025 5:23 pm
PostPosted: Tue Jul 19, 2011 8:40 pm
Duckmeister,
Your and M1100's collective contributions to this thread have been completely redundant.
I'm not back peddaling. I'm only restating, in boring, painstaking detail, the meaning of my original point which so clearly went straight over your head.
Unless you have info on column lengths, which was the original question, go and troll somewhere else.
PostPosted: Tue Jul 19, 2011 8:47 pm
thomas_hb wrote:
Duckmeister,
You said that they only ever fail at low speeds due to the higher torque. This is wrong. I have a good friend that was nearly killed when a column failed at speed.
You are giving incorrect advice and than attacking anyone that tries to make you see your mistake.
You then resort to trying to ridicule and insult anyone that disagrees with you. And you then have the hide to call them a troll.
PostPosted: Tue Jul 19, 2011 8:52 pm
Mr Miagi wrote:
Hey guys,
Long time no post! Havnt driven the little beast out much lately, ive got to work on a few things before hand. One of them being the steering column (im assuming thats its name, but if not, im talking about the column running from the steering wheel to the cars interior floor).
The base of the steering column came loose after the teeth wore completely down, thankfully as I was turning into a carpark (and not doing 80km/h through the hills)! I happened to have a replacement sitting at home, so fitted it in the carpark to get the beast home! Win! :lol:
Anyway, its a good few inches longer (so the steering wheel sits higher) . But god dammit, I liked the old one. It was perfect for cruising. 8)
Are there different types of steering columns, or was my original one shortened? I can get photos/measurements later.
thomas_hb wrote:
Miagi,
You don't need to worry about losing the column splines at 80km/hr - when you're steering at low speeds more torque from your arms is required to turn the wheels. Therefore if you have weak teeth in the spline of your column, this is when they'll fail - not when you're applying very little torque to the steering wheel at higher speeds.
thomas_hb wrote:
Mr Miagi expressed a concern that it could happen at 80km/hr "on the hills".
All I said was that he needn't worry because a high-torque use of an ailing spline was going to break it before a low-torque use. Therefore, there's no need--once the column has been replaced--to drive around worrying about it.
Do i need to explain? If you read what is clearly written then its obvious what Morris and Duckmeister are saying
On topic however, you can get different offset steering wheels so that may be easier then trying to source another steering column of desired length. I also found that using a lowering bracket (when fitted correctly by loosening the steering column U-bolts whilst changing the angle of the rack) can help with an "awkward" steering wheel position.
Just keep driving down the freeway, it will be ok as long as you don't try to park it. Great advice! :roll:
It will fail eventually. It may end up failing at speed. Don't risk it.
There is a member of this forum that has a bad limp as a result of a column failing at speed.
This is the only point I corrected - which was your assertion that I had advised he not bother to replace his already broken spline.
Do I need to crack out the "Not sure if trolling or just stupid?" picture again? I don't want to hurt your feelings again Morrie, but it seems it might be appropriate.
Go to bed, children.
