It is currently Sun Aug 03, 2025 11:36 am
 Post subject: Reamer and guide
PostPosted: Tue Jul 19, 2011 8:38 pm
Hi
I need to buy a reamer and guide to ream a trailing arm bush.
Does anybody have a recomendation of a good supplier of these at a good price and quick postal delivery
Thanks in advance
PostPosted: Tue Jul 19, 2011 8:51 pm
Mods rock!
while I could get a reamer (suttons make them) OK, I couldn't find a pilot long enough so I made one.
Most half decent tool suppliers will be able to order the reamer in.
Hey mate :) how'd you get on with your painting?
I can't tell you whether or not these guys have the adjustable reamer's and pillots your after, but I deal with them quiet a bit at work and their service is always good. If they don't have it can't get it, they'll usually give you some advice on where to look or who to try.
edit... sorry heres the link :P http://www.cuttingtools.com.au/
PostPosted: Tue Jul 19, 2011 9:51 pm
I got a reamer from https://www.machineryhouse.com.au/Reamers-Adjustable
and made my own pilot.
PostPosted: Tue Jul 19, 2011 9:55 pm
How've you found it, if you don't mind my asking? Some of the prices of the Harey Balls stuff is pretty tempting sometimes.... Any good?
PostPosted: Tue Jul 19, 2011 9:57 pm
Yeah PK, it's OK, very well made and cheap too.
I used another new one this week to do rocker bushes, it works fine too. 8)
PostPosted: Tue Jul 19, 2011 9:58 pm
:) Good to know. Thanks... Sorry, just to add to that, I know their Machines are pretty good these days (Don't want to look like I'm bagging Hare and Forbes), certainly as good as anything you'll get anywhere else (and for a hell of a lot less).... I've always walked past their cutters and tools though,,, I'd normally rather buy Suttons or Seco, but sometimes there's just something (like an odd ball reamer) that you're not going to use all the time, and its good to know you can get alright ones for a good price.
PostPosted: Tue Jul 19, 2011 10:18 pm
I use one of their 50mm side and face mills, (3 triangle inserts), works great.
As well as the Seco one I have at work.
PostPosted: Tue Jul 19, 2011 10:26 pm
And their tips are alright? Yeah, we've got a 75mm seco, can't say anything bad about it...
PostPosted: Tue Jul 19, 2011 10:38 pm
No I've not used their tips, so can't comment.
PostPosted: Tue Jul 19, 2011 10:43 pm
No worries. Thanks :)
PostPosted: Tue Jul 19, 2011 11:06 pm
Thanks for your help everyone
and Phat Kat the painting worked out well thanks to your help
Regards
PostPosted: Wed Jul 20, 2011 8:16 pm
Kev, any chance of posting a pic of the reamer guide.
The reamer tool is about the only one i don't have in my special tools collection
and is on the to make list
Ta
Kiwiinwgtn
PostPosted: Wed Jul 20, 2011 8:19 pm
Will do, once I find it.... :wink:
PostPosted: Sat Jul 23, 2011 5:03 pm
Found it...
The reamer pilot body is steel, 0.625" diameter x 160mm long, the thread on the end is 1/4" BSW x 3/4" long. I've screwed it out a bit for clarity.
The sleeve on the pilot is HDPE plastic, but steel would be fine. The turned diameter is 13/16" as I used to ream the bush out with the needle bearing still in, then pull the bearing out. Why? it worked for me... :lol: If you want to do the bush with the needle roller out, make the sleeve 1.060" diameter.
Some people use a tapered sleeve, but then you have to hold it up in there somehow whilst you screw the reamer in.
Next time I ream any I will use my toy lathe as discussed last year? in another thread- it would be faster and less hassle.
Like this- (note it will need a guide mounted in the tailstock, or a bigger centre).
