It is currently Sun Aug 03, 2025 11:34 am
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed Jul 20, 2011 7:56 pm
This space for rent
You're all inspiring such confidence... :P
PostPosted: Wed Jul 20, 2011 8:03 pm
Its easier than doing wheel bearings, put it that way.
PostPosted: Wed Jul 20, 2011 8:11 pm
This space for rent
standard AE cast iron guides ... don't seem to shrink when you press them in. The same is not true for bronze guides (the current Minispares supplied ones anyway). They close in
With this in mind and given that I don't have a reamer, is there any benefit in fitting the manganese bronze guides vs. cast iron for a lumpy-cammed roadie 1152 with standard (pressed steel) rocker gear?
I was considering the bronze guides, mainly because they're billed as "higher performance".. but is there any point in my case?
PostPosted: Wed Jul 20, 2011 8:13 pm
Iron ones are pretty good. Nothing really wrong with them... they last pretty well.
PostPosted: Wed Jul 20, 2011 8:18 pm
I would not use the manganese bronze guides on a road motor unless you have a good reason.
My only reason is all my valves in this head are plain stem S/S, and they don't wear well with iron guides.
If you want the best, send the head away to get K-liners fitted into the iron guides. These are a thin spiral bronze bushing, very popular in race motors.
But they are not cheap (there again neither are bronze guides). :wink:
PostPosted: Wed Jul 20, 2011 8:25 pm
This space for rent
Cool, cast iron it is then. Thanks gents 8)
Now, to get these kids into bed so I can retire to the garage and get the head apart :lol:
PostPosted: Wed Jul 20, 2011 10:02 pm
I think last time i had mine done they were $20 per guide, all up $160 for the head, was four years ago though. I don't think that is expensive for the functional performance you get.
PostPosted: Wed Jul 20, 2011 11:23 pm
This space for rent
I don't think I need that sort of performance, this is just my roadie small bore after all.
So after a couple of hours in the shed, I have the head apart. A little Ghetto™ played its part getting the valves out in the form of my trusty Quick-Grip hand clamp nee valve spring compressor :D I did well, only one collet went flying across the garage - and I found it! 8)
7 valves had now hard & brittle stem seals fitted - #4 exhaust was missing entirely, #3 exhaust was broken and the others intact. Even though they were extremely brittle it seems the others were still doing their job pretty well after all this time.
Chambers look pretty good, considering the amount of oil being burnt.
A bit of gentle persuasion with a brass drift and BFH had the guides out. You were almost right Mick, all but #4 came out pretty easily.. #4 took a little less gentle persuasion but succumbed regardless.
The guides. Interestingly, 7 are knurled, one is not...
Valve seats also look surprisingly good for 10-year-olds - no sign of pitting or recession. I've always used Flashlube in this motor because I didn't know whether or not it had unleaded seats fitted, and for that matter I've never actually seen a head with them in. Can anyone tell me if this has them?
So, now at least I know what I'm dealing with :)
PostPosted: Thu Jul 21, 2011 12:14 am
Looking at your photo, the arrow I've drawn is pointing at what appears to be the edge of a seat insert where it meets the cast iron.... looks like its been converted to me :) Try scratching it with a scribe (or a shank, since we're all ghetto now :P ) and see if you can feel a gap, or a step or something.... but yeah, looks like its been done :)
PostPosted: Thu Jul 21, 2011 8:33 am
Yep looks like inserts there to me.
re the valve stem seals- the common black ones (with a spring or not) go hard pretty quick. Buy some Viton ones- many places eg Karcraft stock them now. A bit dearer but worth it.
PostPosted: Thu Jul 21, 2011 10:45 am
This space for rent
Ah, excellent -- I was going to ask you where you get those. Thanks!
PostPosted: Thu Jul 21, 2011 2:33 pm
I have been bringing some Vitons in from USA, but now they are available here it's really not worth the trouble.
BTW some Nissan ones fit too... not sure what motor but I'll find the pic.
Nissan 1400. Looks the same as mine except the seal bit on mine is blue.
They will fit the guides whether they have the groove in, or not. They are a push on fit- but I use a smear of Loctite 262 to be sure, to be sure...
Pic borrowed from our friends in Seth Efrika...
PostPosted: Fri Jul 22, 2011 2:30 pm
This space for rent
Well, valve guides and viton stem seals are on their way from Karcraft.
Couple of questions re: the valves...
1. What's considered acceptable in terms of stem wear? I have 0.280" stems measuring generally between 0.279" and 0.2785".
2. Valve heads measure 1.065" (exhaust) and 1.220" (31.00mm inlet), both with wide collets. I can find reference to the exhaust being an oversize small-bore part, but the only 1.220" valve I can find is a 1275 radius-colletted exhaust valve.
Anyone recognise the 31mm wide-collet inlet valve?
[edit] Belay that, found it, it's a 12G296: http://www.minis.com.au/minis/catalog/p ... cts_id=691
PostPosted: Fri Jul 22, 2011 3:25 pm
1.219" (31mm) wide collet inlet is a standard 998 Cooper valve.
PostPosted: Fri Jul 22, 2011 8:19 pm
Simon, are you still after a shop to get it sorted? And is Airport West to far out of your way?
