It is currently Thu Aug 07, 2025 12:49 pm
 Post subject: dash light ?
PostPosted: Sat Jul 23, 2011 8:42 pm
Die Die Die!!
hey i was wondering if someone could tell me what the red light under the middle clock on a rover set of tripple dash clocks means as mine has been on and off here and there over the last 2-3 days and the writing has worn off of it..
PostPosted: Sat Jul 23, 2011 8:52 pm
One is oil, the other is alternator.
PostPosted: Sat Jul 23, 2011 8:53 pm
Wouldn't that be your alternator light?
You're so square
Baby I don't care
PostPosted: Sat Jul 23, 2011 9:06 pm
Die Die Die!!
i realise that harley.. but which one is wich..
im guessing its the alternator, as i saw it tonight and i just changed the oil earlier today so im positive its full..
just after some confirmation..
PostPosted: Sat Jul 23, 2011 9:15 pm
From memory oil is on the left.
Which should be amber, and red for your alternator.
Tyson.
PostPosted: Sat Jul 23, 2011 9:16 pm
Die Die Die!!
ahh cheers, looks like ill be getting my alternator checked out soon as i can then..
PostPosted: Sat Jul 23, 2011 9:17 pm
I'd also check your oil level while you're there :wink:
Die Die Die!!
just changed the oil today... its definately not that :)
PostPosted: Sat Jul 23, 2011 9:27 pm
Check the pulley is tight on the alternator, if its loose it'll slip at higher revs and the light will come on. If its on at idle and low revs, its the alternator itself.
