It is currently Wed Aug 13, 2025 9:02 am
 Post subject: Lighter
PostPosted: Wed Jul 27, 2011 5:54 pm
Only reason I would need a lighter socket in the car would be to charge the mobile phone - under the dash rail is the obvious spot but has anyone put one under the back seat? - would like to not see it
David L
PostPosted: Wed Jul 27, 2011 5:58 pm
I've got one in the 850, and I just put it under the dash rail, but pushed it right back toward the firewall
Means I have to plug my charger in by touch, instead of seeing where it's going, but it's invisible and easy enough to use.
You're so square
Baby I don't care
 Post subject: Re: Lighter
PostPosted: Wed Jul 27, 2011 6:11 pm
Mods rock!
I had my radio / cassette play there in one car. Was quite good actually.
PostPosted: Wed Jul 27, 2011 6:40 pm
Thanks guys - I'll look at putting it under the dash rail toward the firewall - might even look at putting one in the rear side pocket.
In the 60's I had one of these;
It fitted in the rear pocket and with the handle horizontal it wedged it in with a gap in front of the speaker. One tape held a whole LP each way so with auto reverse you got to play two LPs - Beatles all the way :lol:
David L
PostPosted: Wed Jul 27, 2011 8:14 pm
I got one of these 12v acc sockets from ARB.
As Adam mentioned mounted it on the passenger side up under the shelf far enough toward the firewall that it is out of site. Because it's all black and with the cap in it really hides in the shadows.
I tried one under the back seat but found it a pain because then your phone ends up on the floor/passenger seat.
Also a Navman is the other handy use for a socket and again the cord won't often reach.
Acc plugs tend to fit them in these better than a "cigarette lighter" socket too.
PostPosted: Wed Jul 27, 2011 8:54 pm
I've used these several times before - similar to the ARB one.
http://www.jaycar.com.au/productView.asp?ID=PS2015&keywords=12v+socket&form=KEYWORD
You can even mount them with double-sided tape if you don't want to drill holes.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Wed Jul 27, 2011 9:10 pm
I like them both - Jaycar wll be easier for me to pickup though - thanks for the input
David L
PostPosted: Wed Jul 27, 2011 11:48 pm
I have ones in bluey in both door pockets and rear seat pockets out of view for personal items, whether it be ipod, iphone, phone or what have you, then have another 4 plug connector under the dash out of view for anything that pop's up like a GPS, video camera, CB, fridge or whatever it may be..
PostPosted: Thu Jul 28, 2011 8:16 am
Die Die Die!!
just mount it in your plastic airconditioning cover... oh wait..
PostPosted: Thu Jul 28, 2011 9:28 am
I am needing to do the same , where would be the best place to wire it in ?, the fuse box or into the ignition switch with an inline fuse.
PostPosted: Thu Jul 28, 2011 9:45 am
This thread has helped my thinking and I will put a switched one off the ignition under the dash and another one in the rear passenger side pocket straight from the fuse box for running car fridge or lights I want on when the ignition is off. I already have a heavy red/black wire I included in the wire loom in case I needed it.
David L
PostPosted: Thu Jul 28, 2011 10:05 am
I've got one mounted up near the roof of my enclosed trailer too, so I can run a car fridge in there. I set up all my cars to have a fused 12v supply through the spare (AUX) pin on the trailer plug.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Fri Oct 07, 2011 11:49 am
ok I'm gonna have a go installing a lighter for phone charger / ipod etc
I read somewhere on here that it is wise to put in a fuse between the lighter and power
what size fuse is recommended?
also, it is a positive earth so excuse me for being dumb on this, I would be taking it I use the red wire as the earth and hook the black one up on the back of the ignition?
cheers in advance for your wisdom!
PostPosted: Fri Oct 07, 2011 12:16 pm
another idea would be to install a USB port somewhere, its 12v and far more discrete, and versatile.
So... I'm Seifer
PostPosted: Fri Oct 07, 2011 12:20 pm
USB is 5 volts, not 12.
Users browsing this forum: No registered users and 267 guests
