Kurross wrote:
Afternoon all,
This might sound pretty crazy, but has anyone had a hole to access pedel box from engine bay?
you may have read from my other recent thread, I have grinded off a dodgy bracket below the clutch and brake cylinders, with the plan to replace, however, removing the old one revealed a hole.
I had planed on welding a new bracket on (covering hole), however, last night when I removed the 2 master cylinders the hole made the task of removing clevis pin much easier.
So I was thinking maybe bolt the bracket on instead, making it removable.
Does this sound crazy or what? I.d be interested in your thoughts...[/i]
crickey,, if its what I think is done.. heck the Previous owner obviosuly didnt have paitence...
It ain't that hard to get to the clevis pins from inside... just go buy a pair of very long nose pliers a torch, and you'll have it out in 2 secs...
I say weld the hole or whatever it is up, make it look right,, but it's up to you mate..
