It is currently Tue Jul 29, 2025 1:24 am
Post new topic Reply to topic  [ 153 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11  Next
PostPosted: Mon Aug 15, 2011 8:23 am
Brilliant...
Thanks for that... That one is definitely going in the bookmarks... :lol:
There is a few other things on my new loom that are a bit confusing, but I'll see if I can sort them out myself now ...
8)
Dusk Blue
1964 850
PostPosted: Wed Aug 17, 2011 6:02 pm
Ok I did my first test run of all my new electrics now that i have most of it all together, but i have a couple of problems..
Firstly there is parts on the back of the spedo that i don't now what is supposed to be wired to.
The little plug looking box thing.
there isn't anything like that on my wiring diagrams that i could see. I don't think i have spare wires that have nowhere to go.. :?
I guess its not on the diagram because it is a later speedo. but do i need this part wired in?
And my hi-beams don't work. Would the fact that i have not wired in the speedo affect this? I thought mabe that some wires need to be connected to the back of the gauge on the lights mabe, as i noticed that the wiper motor didn't work until i connected the wires to the fuel gauge on the back of it.
Any ideas?
Dusk Blue
1964 850
PostPosted: Wed Aug 17, 2011 7:25 pm
That little box is the `voltage stabilizer' for the temp and fuel gauges.
It gives them a regulated 10V output.
If you run them without using it they will read high, and variably.
Wiring digram shows how they are hooked up.
I use one of wombat's electronic ones instead- more accurate and reliable. Body or road vibrations can upset those old originals..
PostPosted: Wed Aug 17, 2011 7:39 pm
ok, thanks.
What about my hi-beam?
Does all the wires need to be hooked up to the speedo cluster for it to work?
Dusk Blue
1964 850
PostPosted: Wed Aug 17, 2011 7:50 pm
High beam works whether or not the speedo lamps are connected.
Check your wiring, also the high/low beam switch.
PostPosted: Thu Aug 18, 2011 9:34 am
Problem solved.. 8)
I just swapped two of the wires on the floor dipper switch and Hey Presto!!!!
Thanks Again dr
I think i need to change the topic of this thread to " Save me drmini!!!" :lol: :lol: :lol:
Dusk Blue
1964 850
PostPosted: Sun Feb 05, 2012 9:38 am
Ok, i am pulling my finger out to finish my mini finally.
So i'm just fitting all the final engine bits before firing it up (hopefully) and i am just a bit confused with this different carby
Are those free hose connections on the left hand side of the picture supposed to be hooked up to anything???
Its just a bit different to the old carb so im not sure.
Dusk Blue
1964 850
PostPosted: Sun Feb 05, 2012 2:18 pm
Either hook that big breather connection to the engine (rocker cover or sideplate) or plug it off... :wink:
PostPosted: Sun Feb 05, 2012 3:29 pm
Thanks doc 8)
Dusk Blue
1964 850
PostPosted: Wed Jun 06, 2012 2:34 pm
Ok, another wiring question..
I have this temp gauge..
But I don't know how it is wired up..
I had a search , but I couldn't find what I was looking for.
The little marks stamped up the top are a "T" and a "B".
Dusk Blue
1964 850
PostPosted: Wed Jun 06, 2012 3:20 pm
T = transmitter (in head).
B= battery = 12V switched supply.
PostPosted: Wed Jun 06, 2012 3:25 pm
the other terminal (at the bottom) is for the earth
PostPosted: Wed Jun 06, 2012 4:11 pm
Ok, thanks guys...
So does this need to go thru the regulator on the back of the speedo (see above posts)??
Dusk Blue
1964 850
PostPosted: Wed Jun 06, 2012 4:13 pm
NO, as it's aftermarket, not a Smiths Mini one.
12V will be fine. (the Mini V stabilizer is only 10V).
PostPosted: Wed Jun 06, 2012 4:48 pm
Ok, easy..
So only the factory fuel gauge under the Speedo needs to run thru it then?
I think I can manage that. :D
Dusk Blue
1964 850
