Yep, it's the last of the Aussie Mokes (very close to it being 1982 compliance) and had a cylindrical tank that took up the whole side pannier. No room in there for a pump. EDIT actually, it may fit a small one in the top corner...
See here: (fish oil not rust)
Now it has this tank, which in the photo has been fitted with the pipe from the old tank that coils around so that fuel vapours condense. That goes to the charcoal canister:
As you can see both tanks have their outlets at the top and the fuel line runs out the top corner of the compartment, into the passenger space behind a trim piece then into the engine bay right above the passenger side suspension tower. I have my fuel pump adjacent to the radiator expansion tank:
It and the fuel line are now covered in insulating foam and foil to stop the exhaust heat from cooking them.
Keen observers will note that the new tank has a huge hole in it. This is for fitting an in-tank EFI pump for my EFI project. Since that project was a fail due to my fabrication skills, I may use my cross-flow head on the moke and make it EFI. The 850's engine is a LONG way off anyway.
M
