It is currently Wed Aug 20, 2025 10:48 pm
 Post subject: snapped manifold stud
PostPosted: Sun Aug 21, 2011 8:26 pm
As per the subject, i have shaped a manifold stud in half been trying to. Losen it but its way too tight any suggestions??
74 clubby,the daily drive.
73 clubby, slow restoration :)
76 clubby shell, still waiting for some lovin.
Jordy....
PostPosted: Sun Aug 21, 2011 8:35 pm
Is any of it sticking out, or did it break flush or below the surface?
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Sun Aug 21, 2011 8:40 pm
How much stud is left coming out of the head ?
You can get a tool for removing studs , and the Snap - On brand one that i have seen ,
worked really well . Someone on here may have a picture of one so you can see what they look like .Check out some reputable tool sellers to see what they have .
umm yer have fun lol my brother broke one and he had to either take the head off or pull the engine out to fix his
PostPosted: Sun Aug 21, 2011 8:48 pm
If there is any stud left, put two nuts on the stud, lock the nuts together and then try undo the stud.
PostPosted: Sun Aug 21, 2011 9:07 pm
whatever you do...
DON'T TRY TO USE AN "EASY-OUT" !!!
if there isn't any stud poking out, remove the head before you try anything, its just too awkward otherwise - always ends in pain
PostPosted: Sun Aug 21, 2011 9:39 pm
If its busted off flush, drill a hole in it, belt in a suitable allen key and twist it out. Worked everytime for me
Master of the Moggie Army & Founder of Awesomestock2010
PostPosted: Sun Aug 21, 2011 11:31 pm
I've found torx bits work very well as "easy outs" :D
The only times i've seen people using easy outs they have broken, making it even worse
PostPosted: Mon Aug 22, 2011 12:01 am
Im yet to find an easy out that works, If that doesnt work then drill through and helicoil. If you dont have a pedestal drill then find someone who does and make sure its square.
Simplify and add lightness
PostPosted: Mon Aug 22, 2011 8:23 am
In my trade I was taught to do this properly....
Drill it on centre (and square) to the tapping size for that thread, then screw a tap in. Bingo the stud's remains come out easy.
If the stud is broken off crooked I drill it out in the mill, using a slot drill not a twist drill.
:wink:
