It is currently Wed Jul 30, 2025 10:14 am
 Post subject: Riddle me this "Temp"
PostPosted: Tue Aug 23, 2011 7:50 pm
Never had a problem A Mini's Tempture. but this is strange
New engine and all has been good till now. had a few dramers with the engine running rich and the leads and coil but they are all fixed now.
Whats happening is when I put the brake on temp goes up by 5-10 degree's. I thought maybe the thermostat wasn't working so changed that & flushed the system 4 times and also pumped the top hose for good measure (air bubble). Nothing has changed. So I thought I would test a few things. Does it happen with the clutch only "nope" Just Up hill or down hill "nope"
While Parked on the Driveway (up Hill) hand brake on, press the brake and Temp rises 10 degrees :shock: WTH
:roll:
PostPosted: Tue Aug 23, 2011 8:13 pm
earth problem Gaf
Master of the Moggie Army & Founder of Awesomestock2010
PostPosted: Tue Aug 23, 2011 8:14 pm
electric gauge? i'd be chasing the smoke in the wires first before validating the temp rise. :)
PostPosted: Tue Aug 23, 2011 8:28 pm
Check the volts running to gauge when you put your foot on the brake, sounds like brake light circuit is pulling the volts away from the rest of the circuits.
If it is I would start looking at all the earth points and clean them up, then clean fittings in rear lights.
Cheers Pete
PostPosted: Tue Aug 23, 2011 8:30 pm
I would agree also but its steady all the way to 80. But I will check anyway tomorrow. Another thing I will try tomorrow is take the air filter off and see if that has a differnace
PostPosted: Tue Aug 23, 2011 8:34 pm
Does it still do it with the motor stopped? (but with the key on)
PostPosted: Tue Aug 23, 2011 8:35 pm
cheers Pete, All connections are new and different circuits. I will have to investigate more
PostPosted: Tue Aug 23, 2011 8:37 pm
didn't try that but will at work..What would that mean Morris
PostPosted: Tue Aug 23, 2011 8:41 pm
I had a Gemini years ago with a temp gauge that "ticked" slightly in time with the indicators. I cleaned up all the earths under the dash and the problem didn't get any better. Finally the alternator gave way and I replaced it with an internally regulated one. Problem solved! WTF?
Not saying this is your problem here though. Earth/wiring issues are more likely.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
It would mean that it has nothing to do with the motor and everything to do with the wiring.
PostPosted: Tue Aug 23, 2011 8:51 pm
cheers Ill look into it
PostPosted: Wed Aug 24, 2011 7:27 pm
Yep that has to be it then. Checked this out this morning. Also found checked this afternoon. after parking the car and temp was 100 I turned the motor off and turn the key to Acc..Hmm 80. Turn the motor back on and its 110. Time to replace all my gauges and recheck all wires.
Cheers Guys
PostPosted: Wed Aug 24, 2011 7:32 pm
Is it a Smiths temp gauge? If so check the voltage stabilizer on back of speedo (unless you've replaced it with a wombat special).
PostPosted: Wed Aug 24, 2011 7:41 pm
I would be interested in this test..
PostPosted: Wed Aug 24, 2011 7:48 pm
If it's one of mine it would be faulty if that is happening - doesn't matter what is happening on the input side the output never moves off 10 volts.
If it is mine then it's covered under warranty :wink:
David L
Users browsing this forum: Barkfast, timmy201 and 30 guests
