It is currently Fri Jul 25, 2025 10:30 pm
PostPosted: Sun Aug 28, 2011 7:55 pm
The spacers on the rear bearings are important, they help to stiffen the stub axle.
+1. While the spacer can be left out, it is a better idea to fit it.
Steve
PostPosted: Sun Aug 28, 2011 8:00 pm
We used to fit them to Production Cars in the early 90s. (Commodores) Even though they were illegal at the time it was better to have them than to break a stub axle.
A Group A Mustang that I used to play with had the Zakspeed struts out of Johnsons first Stang. It had nice aluminium hubs and neat spacers with a small stack of shims. As the bearing cups worked themselves into the aluminium you would remove a shim to return things back to normal!
Any wonder Johnson replaced them with Harrop parts.
PostPosted: Tue Aug 30, 2011 9:58 am
Ordered some new wheel bearings from Karcraft.
They don't stock Timken as they are now very expensive.
The new bearings seem to be the same as the ones I have from the UK.
Will now be looking for some thin packing shims to place in the centre of the bearings to try and pack out 3 or 4 thou.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Aug 30, 2011 2:20 pm
I use crank shims, the ones used to align the crank/cam gears. A little bigger in the ID, but do the job.
Steve
PostPosted: Tue Aug 30, 2011 2:46 pm
Never had to shim the rears but could you use the shims that you get with ball joints or are they too large ?
Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Tue Aug 30, 2011 2:52 pm
if the order hasn't been sent add a few (karcraft part no. 6K628) to the order
otherwise I have couple spare if you need them
PostPosted: Tue Aug 30, 2011 3:11 pm
This space for rent
Beanie
They really are too large, but I've used them in the past when they're all I've had, to no ill effect.
Users browsing this forum: Barkfast and 95 guests
