It is currently Sat Jul 05, 2025 2:45 pm
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue Jun 22, 2004 7:25 am
68Delux,
The Honda discs WILL NOT FIT inside S inward offset Contessas. Not enough room.
Only Cooper 7" or S 7.5" ones will go in there... :cry: They are designed for it.
Even if you turn the Honda discs down to less than 7.9", the caliper will still foul the wheel. Honda discs need the `normal offset' Contessa wheels (and flares...).
No you won't find spacers. They are 2 different wheels. The S offset ones the inner flange of the wheel is 20mm or more further in when mounted on car.
PostPosted: Tue Jun 22, 2004 9:54 am
Oh ok got it! (sorry for being a pest, it can get really confusing for a newbie :oops: )
So with my wheels will this fit straight in and not require flares:
http://www.minidirectaus.com/web/Item/C ... Detail.cfm
cheers,
Chong
PostPosted: Tue Jun 22, 2004 1:06 pm
68delux
You still have not provided enough information to answer your query. :)
http://www.stingrays.dk/wheels/ROHContessa.jpg
Look at this picture. Notice the distance the centre of the wheel (where the nuts fit on) is inwards from the edge of the rim. These are standard offset (not LS or S offset) 10 x 5 contessa. Sometimes called "deep dish".
If you have exactly the same rims on your car now, you will need flares to run these wheels with Cooper S disks.
If the centre is closer to the edge of the rim, you have LS rims and should be able to run S disk brakes without flares.
Check your car and report back before you reply. 8)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Tue Jun 22, 2004 1:46 pm
Sorry foe being a bit of a newbie... :(
Here is a (not so clear) pic of my actual wheels:
Can you tell by the pic which type of contessa wheels they are? Do you have an example pic of the LS rims?
I looked at the car and the inner part where the nuts go onto the wheel is approx 20mm inwards from the rim of the wheel.
PostPosted: Tue Jun 22, 2004 2:19 pm
they are Ls contestas arent they ?
lookin for another clubby
PostPosted: Tue Jun 22, 2004 3:05 pm
You tell me :( :?
PostPosted: Tue Jun 22, 2004 4:22 pm
Yes, they ARE LS rims. :D
You must already have spacer drums all around too, judging by the way they are filling the guards. You are in luck!
You CAN fit Cooper S front disks and keep these wheels and you will not have to add flares. Keep in mind you will also need to change the rear wheel cylinders to the smaller Cooper S ones as well.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Tue Jun 22, 2004 5:44 pm
WOOOHOOO!!! :D :D :D
That is the best news yet!!! I will jack her up and check for the spacer drums. What do they look like compared to normal drums?
I was hoping so cause I had a look at her again and the wheels are *JUST* inside of the wheel arcs, perhaps within mere mm if not flush against the outside of the wheel arcs.
PostPosted: Tue Jun 22, 2004 5:48 pm
I'm confused, if i put the cooper S discs in the front then why would I need to change anything at the back? :?
PostPosted: Tue Jun 22, 2004 5:50 pm
Oh you mean the brake cylinder! gosh I am such a newbie :roll: *studying the Leyland manual* :mrgreen:
[Edit] yes studying the parts catalogue it looks like I have the "stepped out" drums with extra bit sticking out of the middle, I will have to double check. Will report back later.
by the way, Thanks to everyone who answered my questions, you guys rock! :D
PostPosted: Tue Jun 22, 2004 7:04 pm
Don't stress about being a newbie, we all gotta start somewhere!
8)
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Tue Jun 22, 2004 9:26 pm
You can't be that much of a newbie.......I still can't work out how to get a pic in the middle of my text! :?
Minimad
You can take the boy out of the racer.........but not the racer out of the boy!
PostPosted: Tue Jun 22, 2004 9:37 pm
Oh well now, computers are my thing! :)
I am about as good with them as (I dare say) Dr Mini is good at minis 8)
Just use the IMG button and paste the URL of your image, click preview then continue typing! that's it! :)
Before you ask, to get your image to show you need to host it, usually through free sites like geocities or sometimes your Internet Provider gives you space on their server to upload the files as part of your account with them, thats the only real hard part...
I checked the wheels, they are only 20mm or less inwards from the outer rim of the wheel. I also looked at the drums, they stick out in the middle by roughly 1.5 to 2 inches.
So for sure I have LS Contessas?
PostPosted: Tue Jun 22, 2004 10:40 pm
They look like it to me too.
To be sure, stick a tape measure inside the wheel, measure from the mounting flange to theextreme inside edge of rim, and post the dimension here.
PostPosted: Wed Jun 23, 2004 12:27 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
dude if ya need help i'm able to help on weekends just call 0412 938 072
i live in smithfield but moveing to penrith soon
makka
