It is currently Sat Aug 02, 2025 2:16 pm
PostPosted: Sat Sep 03, 2011 1:04 pm
G'day all,
Just wondering what options there are for covering/filling the hole in the firewall (in front of the carby).
I have seen some plates covering the hole, but i think my ramtube thingy will poke through (when i put my engine back in), so i need something else that hides the wires from the speedo.
PostPosted: Sat Sep 03, 2011 1:35 pm
I take it you don't want to use the original type felt backed vinyl that covers the whole firewall? It makes it easy to fix things when you need to get behind it.
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Sat Sep 03, 2011 6:26 pm
Havent seen these, sounds good. Though i'm guessing it doesnt allow the the carby ramtube to poke through the hole?
PostPosted: Sat Sep 03, 2011 6:45 pm
here's what it looks like
http://www.minis.com.au/minis/catalog/p ... cts_id=288
PostPosted: Sun Sep 04, 2011 6:39 pm
From my non expert knowledge from what I have seen, if your ramtube/s are that long you will need to move the speedo anyway and install a box into the firewall. With a Redline 3005 type manifold and webber with ramflo filter it will still fit. Others will no doubt offer better advice but thought I would reply to try and help create discussion. It may help if you let us know what your carby and manifold set up is. Cheers.
Member: VMCI #2474
PostPosted: Sun Sep 04, 2011 6:54 pm
what type of carb/manifold are you running? you could possibly buy a shorter ramtube and fit a filter sock over the ramtube.
PostPosted: Mon Sep 05, 2011 11:55 am
I'm not a 100% certain it pokes through, but pretty sure it does.. (its been a while since the engine was in)
here is a pic of the carby, manifold etc... I have one of those sock/foam filters to go over it but havnt attached yet.
PostPosted: Mon Sep 05, 2011 5:15 pm
I can't really see why that wouldn't fit in normally.
It dosn't look any longer than my ramflo filter and it has heaps of room.
Dusk Blue
1964 850
