It is currently Sat Aug 16, 2025 1:57 pm
 Post subject: weird noises!
PostPosted: Mon Sep 05, 2011 8:57 pm
To all you mini psychics!
My mini has developed a worrying knocking noise coming from diff/gear box/bottom of the engine area. The noise tends to occur after 5-10 minutes of driving, and only under cruising and decelleration. the knocking is related to the speed of the car (as the car slows down, the knocking slows). It also tends to happen when im turning right.
The knocking has no effect on performance.
I know this is a long shot, but has anyone experienced anything like this before? im stumped and cant think of what it can be! (CV's are new, all boots are secured)
thanks!
PostPosted: Mon Sep 05, 2011 9:20 pm
Small asian stuck under car?
Master of the Moggie Army & Founder of Awesomestock2010
PostPosted: Mon Sep 05, 2011 9:31 pm
Perhaps a prolem with your serpentine belt-
PostPosted: Mon Sep 05, 2011 9:40 pm
Tomboss Breweros
:cry: My carpet python died recently :cry:
Dave, are the inner c/v's new? and are the upper engine steady bushes ok, i've had some weird clunking noises from the inner c/v's for both of those reasons.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Mon Sep 05, 2011 9:50 pm
Sounds like a pot or uni joint?
PostPosted: Mon Sep 05, 2011 9:52 pm
SSSSSSSSSSSSSSSSSSSSSseriously though
PostPosted: Mon Sep 05, 2011 9:56 pm
I'd also be checking the rubbers in the engine steadies just to be sure
PostPosted: Mon Sep 05, 2011 10:55 pm
Don't get us started on the pot joint joke.
Wasn't there something that, along with the term 'roast', that got a few threads locked not too long ago?
:lol:
Dave. try to describe the sound for us... Or upload a clip!
(It is 2011 afterall).
PostPosted: Tue Sep 06, 2011 6:52 am
Hi guys,
Years ago I a similar issue, trying to chase a knocking sound in the drive train. I could feel it under my left foot on the fire wall under the clutch pedal. I thought it was on the r/h side, but turned out to be a collapsed l/h inner wheel bearing, the one up against the CV joint. Destroyed the CV as well as, the bearing had spun on the CV & dug into the CV.
Cheers Shane
PostPosted: Tue Sep 06, 2011 2:54 pm
MiniVLT wrote:
Hi guys,
Cheers Shane
That was my next suggestion. It would have to be royally shagged to make a knocking noise, usually a wheel bearing whirs for a while before then...
PostPosted: Tue Sep 06, 2011 2:56 pm
:lol:
Well I was being serious...
What type of gearbox is it? that will tell us if it's a pot joint driven or rubber uni joint. I've seen worn rubber uni joints wear all the way through the gearbox casing, so beware! Jack the car up and have a look around, it should be pretty obvious in plain sight if the noise is that loud and the problem is outside the engine.
PostPosted: Tue Sep 06, 2011 3:11 pm
I've heard of something like this, maybe it could be the drive shaft coupling hitting the extractors, that's if you have extractors?.... but your noise is probably something else
PostPosted: Tue Sep 06, 2011 3:30 pm
I had a similar problem with rubber uni joints, they came undone. As they become looser they started hitting the gearbox after passing a certain speed. I could not figure out what the thumping was.
Eventually they fell apart, the car stopped and I had a large wear mark in the back of my gearbox casing........6 hours from home. A VERY helpful Tumut local helped me out big time.
PostPosted: Tue Sep 06, 2011 8:12 pm
I have Uni joints. I jacked the car up over the weekend and had a good look around. there was a very small amount of play when I rotated the pot joint by hand. I couldn't find anything that was fouling on the gearbox/extractors anywhere.
Shane, it feels very much like you described! I can feel it with my left foot under the clutch pedal.
However, I replaced the CV's, wheel bearings and all when i converted to disc brakes about 9 months ago. I hope that isnt the problem!
Thanks for your suggestions everyone, looks like ill be spending some more hours in the shed over the weekend! I need to get her right before Bay to Birdwood! (there is a mini only section this year!!!!)
PostPosted: Wed Sep 07, 2011 7:58 pm
MiniVLT wrote:
Hi guys,
Cheers Shane
I couldn't here anything over the induction noise of a 45 DCOE on a 9" long manifold with ram tubes. The inlet to the ram tubes was almost 10" inside the cabin! :lol: :lol:
Users browsing this forum: No registered users and 227 guests
