It is currently Thu Aug 14, 2025 9:13 am
 Post subject: Speedo drive - odd size!
PostPosted: Sat Sep 10, 2011 7:21 pm
Hi,
My Moke has a 1990 1275 A+ Auto from a Metro fitted. The speedo has been all over the place for a long time. I traced the problem to a chewed up cable at the gearbox end. So I bought a new standard Mini speedo cable and today I tried to fit it.
The square section of the new cable would not slide into the shaft on the drive gear, at the gearbox end. I removed the drive gear and compared it to the ones in every other Mini gearbox I had in the shed. This one has been designed for a smaller cable end - still a square drive, but the square is about 0.5mm smaller so a normal mini cable doesn't fit!!
Has anyone seen this issue before?
Thanks,
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sat Sep 10, 2011 8:20 pm
Can you grind/file the end of the new cable down to fit?
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Sat Sep 10, 2011 8:22 pm
i had a problem with a new speedo cable, too big for gearbox end . had to sand it down to make it fit in the square drive...
PostPosted: Sat Sep 10, 2011 8:25 pm
yep after market cable i bet.. don't they make anything correctly anymore
PostPosted: Sat Sep 10, 2011 9:03 pm
u can sand or file it a bit, just be careful the wires dont start to fray, if they do trim them off .
PostPosted: Sat Sep 10, 2011 9:55 pm
Hi,
The new cable is from Karcraft and is stamped "UK". It fitted every other gearbox I have, including my MG Metro powered Mayfair. It's just this one drive that is a mongrel size. Late Metro automatics must have used a different cable, goodness knows why! Maybe an SPi Auto speedo drive would fit??
I tried the inner cables from my Mayfair and my Traveller, neither fitted the mongrel shaft.
Then I tried to linish the new cable down enough to fit the mongrel shaft, but when I got close the end frayed badly. With the outer layer of inner cable removed it's now too small. The cable can just about rotate inside the shaft, so it's now a bin job. That's what happened to the old cable - it started rotating freely. It seems it was filed down to fit in the past. I can't recall if I did that or not, as it was six years ago.
I think I have a solution. I've been using the cable to drive a speed sensor behind the dash for a signal to my VDO speedo. The sensor fits the mongrel shaft on the gearbox perfectly, so I'm going to relocate it down there. It will require a little grinding and trimming of the part where the speedo cable outer normally fits. This will do away with the need for a cable completely.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Wed Sep 14, 2011 2:48 pm
For the interest of those in the future that may face the same problem, late A series Metros from chassis B5000001 use a speedo cable with a smaller end - part number 401070-60.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Wed Sep 14, 2011 3:07 pm
Thanks for this - now I think I know why I can't get the new cable to fit :evil: Been trying and trying to slide the new inner down the old outer and no way can I get it to "engage" at the bottom
David L
Users browsing this forum: No registered users and 303 guests
